1 - 3 of 3 Posts
We've officially released the Chrysler version. Full details are available on our website here:
Chrysler Technical Information
Some of the significant features are:
  • Birectional controls such as manual cooling fan on/off, ESP shutoff, Transmission module reset
  • ABS module parameter support, such as lateral G's, brake pressure, yaw, steering wheel angle, + many more
  • over 50 supported PCM parameters including knock retard, oil pressure, intake air temp, injector duty cycle, etc
  • TCM support such as transmission temp, torque converter status, converter slip speed, current gear
  • HP and MPG calculation
  • performance timer - 0-60, 1/8, and 1/4 mile
  • high intensity LED warning lights available in a variety of colors including red, blue, green, orange
Check them out:
[url=http://videos.streetfire.net/video/SRT8-Aeroforce-gauges_156324.htm?ref=c91b6dbe-c6a8-43a8-a8c4-9a030172c937]SRT8 Aeroforce gauges[/URL]
Todd
They look GREAT! Is there a local So. CA. vendor that sells them? How about a price range? Can you read trans temp without an addon temp sensor? Regards, Bob.
Yes, you can read trans temp without an additional sensor. It's read right off of the OBD2 port from the OEM sensor in the valve body.
I don't believe there is a vendor in Socal at this time. You can see a list here: Aeroforce dealers.
Thanks!
Todd
1 - 3 of 3 Posts
