1 - 2 of 2 Posts
Hi,
Have an opportunity to acquire what I believe to be a Getrag diff to suit my 07 SRT8 300C. Have been followimg threads about this, but I need to know if the diff is correct. The numbers dont correspond to your threads and the tag describes it as 3.09 ratio.
doesn't come with axels or tailshaft. Supposed to be out of a 2015 SRT Core 300C. The attached pics confirm all this.
Thanks in advance for the replies.
175703
175702
I am not sure about your particular swap, but when I did the Getrag swap into my somewhat modified 05 Magnum R/T, I only had to change the axles and hubs. The driveshaft hooked right up. IIRC, there are different spline counts on the axles and some of the driveshafts don't mate up and you'd have to change the flex end at the differential. With luck, yours will bolt right up. I know there are "how to's" somewhere on these forums for your particular vehicle. Good luck.....and the LSD does make a big difference.
Reactions: dragcharger
1 - 2 of 2 Posts
