Yup, that's for both. That price does not include the mesh inserts or paint.Hey GRIP, just wanted to make sure if the price of the rockers were $399 for both or each. Im assuming both. Thanks for your time.
There are places on the back side of the rocker where the material is thicker, allowing you to drill a hole and attach the mesh with a screw. You'll find it's a very quick and easy procedure if you have a power drill. :fing02:Sounds good. Is there an easy way to install the mesh behind the inserts of the rocker? Like existing brackets or molds on the rocker to install the mesh or is it a DIY deal. Thanks for the help J.D.
