How did the install ever turn out?thanks for the replys guys, the info is much appreciated. Ill give it a go this weekend and try and post some pics
Different ovens have some some variations on what the temperature really is. I would not advise to go up to 300 because that is in the micro-cracking range...The instructions can't be followed word for word.. The bake temperatures listed in the instructions WOULD NOT touch the adhesive holding my OEM 07 housings together, I wound up baking them at 300 degrees, many times, to get the HELL glue, to release it's Kung-Fu Grip![]()
No, the 300C does NOT have a reusable seal. Most lights do but for the 300C you need to remove the old seal and reseal the lights with black outdoor silicone.In the AAC installation video, they say just heat the lights again and reseal, but the instructions say use black silicone caulk....did you guys use black silicone, or just the factory glue? Got my halos yesterday...can't wait to try 'em out!
Oh, and did you all hook them to your parking lights, or are they switched another way?
Thanks ... I'm going to try to tackle this project this weekend. I'll post pics when I'm done.No, the 300C does NOT have a reusable seal. Most lights do but for the 300C you need to remove the old seal and reseal the lights with black outdoor silicone.
Thanks, read through the instructions it will talk more about the silicone. Pick some up from Lowes or Home Depot before you begin the project to help things go faster.Thanks ... I'm going to try to tackle this project this weekend. I'll post pics when I'm done.
BTW, AAC had fast shipping and what appears to be a great product....highly recommended!
Once you have the the housing hot enough take your screwdriver and carefully go around the perimeter of the light (holding the screwdriver parallel to the seal) and loosen everything up. Do this once or twice, put back in the oven, then try again its sure to pop right offOk, attempted this today, but no matter what I tried, I couldn't get the housing apart. I started at 245 for 20 mins, nothing, so tried another 5 mins, nothing, upped it to 265 for another 5, nothing, then 275 for another 5, 285, and finally 295 for about 10 mins. In that bottom corner there was a very slight gap, but it wasn't moving...I used quite a bit of force.
I was afraid to go any higher than 295. Anyone have any suggestions on how to get past this? Do I just have a super-sealed light? I didn't try the other one yet, but if I can't get this one open, I don't want to install this on the other one.
on the bright side, I learned that taking the fascia off really is as simple as everyone says.
I considering trying that, but I was afraid I'd bend it or break it. I'll try that on the next attempt....Once you have the the housing hot enough take your screwdriver and carefully go around the perimeter of the light (holding the screwdriver parallel to the seal) and loosen everything up. Do this once or twice, put back in the oven, then try again its sure to pop right off![]()
