1 - 9 of 9 Posts
I have a Borla aggressive exhaust system and am looking at getting some headers, and was wondering if there was one that was more compatable with this exhaust then the other.
I have the Borlas and added Hedman HTC headers. I love the combination because they arenearly as quiet as stock...until you hit the go pedal....then what a sweet sound.
Did you have to make any modifications or were they more or less plug and play? If you did how much work am I looking at?
It pretty much plug and play, but the header are a little work to put on, cause you have to lift on side of the motor, but that is true for any of the headers...I think
It'll probably cost $500 to $600 to get them installed. That's what it cost to put headers on my 5.7 when I had it.
Discussion Starter · #6 ·
Generaly speaking how much added power do you get from adding headers to your motor? I know it varies depending on your other mods, I am just wondering if it is worth it or not.
No need to lift the motor with the Dynatechs. With the car on ramps, they slid right in. Getting to a few of the bolts were a challenge but doable.
Generally speaking how much added power do you get from adding headers to your motor? I know it varies depending on your other mods, I am just wondering if it is worth it or not.
I noticed quite a bit. The car was (still is) a tire shredder after the long-tube header (and high-flow cats) install. Also, the "quiet" Borla got considerably louder the install :biggrin:
Discussion Starter · #8 ·
I have herd a lot of good things about kooks LT headers so I have been looking into those. In the end however it all comes down to cost so we will see.
1 - 9 of 9 Posts
