Noticed the right headlight wasn't working & the left headlight working. then a couple of days later the left headlight wasn't working and the right headlight was. Has anyone had experience with this problem, problem is on going. Thanks guys
It's not uncommon for failed halogen bulbs to briefly start working again. A break in the filament occurs, then you go over a bump, the break closes, you go over another bump, it opens up again.
Just replace them.
Just replace them.
Hi, Thanks, I'll let you know how i go, Thanks Nick
Hi,
I found both bulbs blown, found cheap 2 for $90 Aus replacement on the net, still had problems with the headlights turning off & on, I took it to an auto electrician, are a couple of people had recommended. He said it was an electrical problem, cost $148 Aus. Problem now fixed, lights are working fine.
