I park in an underground garage when at work. I usually turn on my headlight for safety. Sometimes it's dark enough for the auto-lights to work - sometimes not.
The other day I took "the crew" out to lunch in the 300c. When I came back into the garage, I switched the lights on manually. I parked the car (backed in a spot), turned the headlights back to "A" mode and got out.
Walking towards the buildings door, I pushed "a" button to lock the doors. I looked back a noticed that the headlights were on. In the EVIC, I had turned off the option to turn the lights on when locking the doors. so I thought I mistakenly pressed the unlock button which I have set for 90 seconds of light. So, I reached in my pocket, this time pulled out the key and pushed the lock button. Blink blink of the yellow lights - headlights still on - because if you push the unlock button they will stay on even though you've locked the door.
About 20 minutes later, I get a call from the front desk saying that someone says that your lights are on. I said that it was probably just that I had hit the unlock before going in and that they are probably off by now.
Another 20 minutes later (40 mins for those playing along at home), building secuirty calls me and tells me my lights are on. Humm, maybe they are really on!
Sure enough. They are on. I unlock door and flip the switch to "1" and back to "A." The lights on now off. I relock the doors and the lights remain off.
Haven't had a problem since.
Maybe it was a Twilight Zone Episode?
Any one else seen this bizaarenes?
