Sorry to revive an old thread, but my issue seems to be shared by many. I have no issue with taking my car into the my local dealer, but as the car is now outside of it standard warranty, I want to know as much as possible before I make the call.
I'm having a similar issue with my '13 300 SRT8. Since it started getting cold, my temp controls have no worked reliably and I've had periods where I was being hit with hot air and cold air and I have no ability to change the temperature. Controls are responsive and indicate new settings - but nothing happens.
If I turn off the car (fully) and restart, controls work and temperature does change reliably for several minutes. However, after a bit of time, controls work, but the temperature will not change at all. While driving, if I set the desired temperature and then turn off the climate controls, wait 10-15 seconds and turn them back on I will actually get the desired temperature. The temp controls still do not work after doing this - unless I shut off the climate controls after selecting a new temperature (at least there is a work around in my case).
Latest occurrence was this morning, it was 48 degrees outside and dark (before sunrise). I was able to reproduce several times as made a couple of stops. When I arrived home, I shut of and started the car again. I sat and went from high to low temps (back and forth) several times, no issues. I moved the car a short distance to the garage, and then I couldn't change the temp again. I hear no clicking sounds or anything that is pointing to anything specific - other than the fact the temperature controls do not work.
Any insight into the specifics of the issue and/or part numbers/diagrams would be appreciated. Also - are there any any procedures for testing on the 2012-2015 model year to see if any specific codes are reported (and visible to me without a dealer scanner)?
