I recently purchased a 2013 srt core and have started doing work to upgrade the inside. I've currently done
- Speaker upgrade
- Sub woofer installed
Wanting to upgrade the head unit to the one with sat nav as my next mod but not sure if it is doable.
Any suggestions for interior modifications are welcome!.
Sent from my HTC_0PJA10 using Tapatalk
It is doable. Depending on what head unit you purchase and what functions you have you want to preserve or add, there will be a PacAudio or Metra harness adapter that will assist with those functions.
Awesome! I was just going to put the factory srt head unit in with nav instead of an after market.
That will work fine as long as you get the maps. I don't know, however, if you need a dealer to flash your computer with a sales code for the head unit to work. It should just plug right into the OEM harness with no issue.
