WELCOME!
Here it is straight out of the book....its kinda long. Also, it say you should be outside/near whatevery your programming whether it be a gate or garage door. And to be aware that it will be opening and closing during programming
1. Press and hold the two outer Homelink buttons, and release only when the EVIC display shows "channels cleared" (after 20 seconds). DO NOT hold the buttons for longer than 30 seconds and DO NOT repeat step one to program a second and/or third hand held transmitter to the remaining two Homelink buttons.
2. Position the end of your hand held transmitter 1-3 inches away from the Homelink buttons.
3. Simultaneously press and hold both the Homelink button that you want to train and the hand held transmitter buttons. DO NOT RELEASE THE BUTTONS UNTIL STEP 4 HAS BEEN COMPLETED.
4. The EVIC display will show "channel x training" (where x is channel 1,2 or 3). Release both buttons after the EVIC display shows "Channel X trained"
NOTE: If the EVIC display show "Did Not Train" repeat steps 2-4
5. Press and hold the just trained Home link button and observe the EVIC display. If the EVIC display shows "channel x transmit" programming is complete and your device should activate when the Homelink button is pressed and released.
NOTE: To program the remaining two HomeLink buttons, begin with "Programming"
step two. Do not repeat step one.
