Well this sucks and now I am lost. I am trying to figure out where I am going to get the power from for my Plasma LED lights. My thought was to run them off the 87A circuit for the Fogs (Would this even work?) I figured while the fogs were off, relay to 87A spot, it would power the lights. Then when the fogs turned on they DRL's would shut off.
Sounds easy right? So I pulled out the Owners manual and guess what, Relay's are not listed. I need relay 9 and 16-22 for a 2008. I can not find that list anywhere! I checked the sticky and even printed out the diagram, which looks nothing like my fuse box either. I don't have empty spots in my box, there is a cover and only spots for whats being used.
Can anyone help a fellow out? If this wont work, I guess I could just power them to Hot in Run or something? I was trying to leave out a manual switch so I didn't have to go buy wire and a switch and mount it somewhere having to drill a hole, also I wouldn't have to remember to switch them on everytime.
I also tried this, I turned the key to run, turned on the lights and pulled all the relays, none of them turned the lights off?
