Had my front clip off this weekend for some work that needed to be done, so decided to swap in my projector fogs that I purchased awhile back.
A little backround, I've had a HID fog setup installed on the factory fog housing for a couple years now. This past winter they went out on me. My ballasts came loose and were banging around for awhile and eventually stopped working. Also, the fog light switch never really worked right since installing the HID setup (couldn't turn it off).
While taking out the old equipment, I found I had 1 busted bulb and that same side had some corrosion on the plug that goes into the original harness (maybe shorted out).
Plugged up the new stuff, which included new fog housings & HID bulb/harness. Using the old ballast's. Not working.. Checked the fuse and that's good. Pressed the foglight switch many times.
Now I remember reading at some point that using hid fog's messes with the switch. Is this true? I'd hate to have to start buying random parts. Though in this case I guess it would either be the harness or the ballasts.
As I'm sitting here I also wanted to add, my side markers were not working prior to taking the frond end off. So while swapping out the bulbs I found the housings were melted. How long ago that happened? I haven't a clue. But I was able to get the old bulbs out and swapped in new bulbs and they do indeed work, but this is with no fogs working. Now if you don't know, there is only 1 harness for both the side markers and fog lights.
Any thoughts?
Sorry for the long post. But I think I got everything covered.
MacK
Any thoughts?
MacK
