So, I have been installing lights for years but I still can not figure out the issue with Mopar's. I know that HIDs operate with Xenon gas & do not have filament like regular light bulbs. I know most cars computer system look for a filament bulb. I use the error code correctors & anti-flicker bypass relay with the resistor on it. The lights work fine but every now & then when the lights turn on one of them would be out. But, once I turn them & back on they both turn on. So, I was wondering if I should add a voltage regulator because I'm assuming the headlights aren't drawing enough power to power the HIDs even though I have a relay drawing direct power from the battery. Is anyone else having a similar issue?
