kidcoastal said:
. Also, I want to get some HID's put in my C. which would you reccomend, is there any modifications necessary or will they fit right in, and how much do they cost. Kidcoastal
We should work together on the HID. I have found a Japan Domestic market importer that stocks the 9006XS HID retrofit kits for the 300c and Jeep Grand Cherokee. They need to be wired to the sidemarker lights as opposed to the stock lowbeam harness. The lowbeam power fluctuates down to 8 volts and makes the HID's flicker and pulse. I have seen 2 people succussfully pull off the HID retrofit, once on a magnum and once on a 300c. Most everyone else has had issues due to the voltage fluctuation.
Other than tapping into the sidemarker power harness, there are no other modifications and we should be able to pull off the installation ourselves. Most aftermarket shops won't touch HID retrofits with a 10 foot pole because they are illegal.
The kits I have found are 8300k color temp. Here is an example of how they look:
How comfortable are you with splicing into your wiring harness? I've been considering tackling this mod, but 2 heads may be better than one. I've got full photo documentation and the posts saved for reference also.
I believe they are $625.
