If you go to the Homelink web site, you may be able to find what you want. The units are made by Johnson Controls. I had a problem with range on my 300M aand by going through Johnson Controls they sent me a new module which cured the problem. Give it a try.minichris said:Hi
I'm new here but I hope its OK to ask questions.![]()
I just received my 300c wonderful car.
Here in Europe the Home link is not available as an option, and my question is if some one knows where i could buy a retrofit kit?
Chris
You will have to check with your dealer or DC on that.dreadful said:I was wondering the same thing, but from what I have seen on programming the homelink it ties into the cluster for setting codes....could this be adapted on a base model, or is that just not an option because of the evic??
