After mounting a remote reading thermometer in the stock intake tube of my home made CAI, I discovered there was a significant temperature difference between ambient air and actual intake air temperatures. I went through about 3 different versions of this insulation mod., until I arrived at the current setup. My true intake air temp. now runs at ambient on the highway and 0-8 degrees above ambient around town. Sometimes there will be a little higher difference (depending on how much stop and go), but it usually recovers within about a mile or so. This difference also may increase during summer months, but I'll have to wait to see.
I started Phase 2 by insulating the bottom part of the airbox with foam backed aluminum duct insulation, and building my own air intake tube. Parts for the intake tube were acquired from www.airflow.com. The ABS and duct insulation from Home Depot. The first intake tube was a 4 inch aluminum tube with 1/2 inch of foam backed aluminum insulation around it. A 5 inch aluminum tube was slid over top of it making it a double wall tube. The current setup replaced the 4 in. inner aluminum tube with a 4 inch ID cellular insulated (1/4 inch wall thickness that looks like encased concrete mortar) ABS black pipe that goes from the box to the bend going into the throttle body. (This is where I have my temp. gauge sensor located.) The ABS is wrapped with a layer of two rows of plastic bubble wrap encased on both sides with aluminum foil. This was cut from a front windshield slip-in sun protection visor bought from a local auto parts store. Why bubble wrap?? I researched it on the internet and found it is only surpassed by argon gas as an insulator of heat. The study I used lists insulators in this order of effectiveness: argon, air (bubble wrap), styrofoam, polystyrene (solid), wood, teflon, water, glass, and concrete. I looked at a few other studies which also listed bubble wrap as among the most effective. Any way, then I have the 5 inch aluminum outer tube. As an experiment I have also insulated the elbow where it goes into the throttle body. I have to find a way to sanitize the elbow mod. though. My intake air temp. when cold, in town now runs from minus one degree (might be due to the calibrations of the two units) to plus two degrees of ambient. Around town stop and go after warm up runs 0-8 degrees from ambient with long stops in traffic at the higher end. Within a mile it will cool down to 4-8 degrees of ambient. On the interstate from about 50 mph up it runs at ambient after about 3 miles at speed. After a 15 plus minute stop, start driving at 35-40 mph and cool down from around 100 degrees to coolest takes about 3 miles with the biggest drop (30-40 degrees) taking place within the first mile or so. These tests were done with ambient running between 50-65 degrees. I imagine in warmer temps. the variance from ambient may increase, but I am fairly confident that at highway speeds true intake air temp. will run at or within a couple degrees of ambient. The biggest problem in my opinion is controlling heat soak, as indicated by sub-ambient to near ambient when the engine is cold. I feel the majority of this problem comes from the intake tube. I did not notice much difference after insulating the air box. Is all this worth it? Aside from my love of tinkering, I'd say, yes! I am at about $120 for all mods. and my gas mileage for the last three tanks (205 hrs/5200) miles currently) has been 18.2, 17.9 and 18.4 mpg respectively with about 95% of driving in town and an occasionaly WOT blast. My highway mileage runs 27.5-28.3 mpg at 60-70 mph. Others have documented dyno tests for the air box mod. vs. stock, so I am sure there is also a small increase in power. I have since added more insulation to the top of the airbox and around the main part of the tube. I don't think this is doing much though, but I figure it can't hurt. The only other things I have done are raised tire pressure to 40 PSI, run nothing but regular 87 octane fuel, Mobil 1 synthetic oil and my MDS "on" indicator light.
http://www.300cforums.com/forums/showthread.php?t=4984
As far as the intake mods. go I am satisfied that I am getting more than enough (Two 3 inch ducts into the air box) cool (insulated air box and intake tube) air into the engine. The original mod. cost $10. The latest mods. cost about $110. Still way cheaper than the aftermarket ones and I know the engine is now ingesting the coolest air possible.
