me 2...ive gotten as far as programing and it never takes?lennoxavesosa said:i have a farely older garage door opener, and still can not get my homelink programmed! this thread was from a while ago and it seems that the 'missing steps' have been edited out! i sat and played with the damn thing for about a hour and still couldnt get it programmed. anyone might be able to help me out?
O i held the button down when it said train also pressed and held the garage at same time..so this time ill hold garage opener and when i get into train ill hit the #1 intermittingly and this should make it work???ill give it a tryobiwan said:I had a hard time getting the home link to "learn" but, after you clear the codes by holding down #1 & #3, train the home link with a remote then, place the garage door opener in learn mode, get in the car and press, then release, then press and release again the button you want to learn. It took 3 or 4 press and release on mine but it took. Just pressing and holding the button did not cause it to learn and allow it to open the door. HTH.
