Can i wire my carkit after the stock amp ??
So the sound goes trough all speakers ??
yes, but you'll need multiple channels. Not sure which speaker
option you have but if it is the BA6, then that basically means you'll
need 6 channels.
There are 4 channels to the front, 120hz and up to the dash, 120hz and
down to the door. 2 channels to the rear which are full range.
now you could get one of the many OEM adapters available and combine
the signals to get a full range output and run that to the amp.
take a look at this list:
RF 3sixty.1, 3sixty.2
JL Cleansweep + summing unit
AudioControl LC6 or LC8
Alpine PXE-H650
MTX ReQ, ReQ5
Any of the above will take the output after the amp and give you
a signal you can use any way you choose. You then run that
output to the amps you want to use and run the speakers you want
to run.
hope this helps
