Hey All
I have another problem I've been putting off to fix, but being in the Florida heat, it can't wait any longer. My A/C doesn't seem to be working, but let me give you a back story first.
It started out about a year ago
The A/C on the passengers side started to become warm, even on the coldest settings.
I put it off because the AC wasn't really necessary at that time of the year and the drivers side still worked. Eventually the drivers side turned to warm air as well.
It turned out that there was a small leak and I had to replace an O ring on the passengers side.
After that the A/C was back to being ice cold.
This summer the same thing happened; passenger side went out then drivers side.
I had new Freon put in, it seemed to be pretty empty, and it was ice cold again.
This was about a month ago.
Now both sides are warm once again, and in this florida heat AC is a must.
Has any run into this problem where the AC keeps doing this?
Do you think it's another leak?
I'd prefer not going to the stealership for obvious reasons.
Any input is appreciated, Thanks!
