We all are going to need to know how to get the computer to respond to mods we do(those who mod, that is). Without the ability to move the PCMs targets around, we are going to run into some serious problems with aftermarket parts.
If we fake the IAT into thinking it is much hotter than it really is, it will start dumping extra fuel to richen the PCM up(know this from my drive through Yuma in 122 degree heat, MPG dropped dramatically even going to lower speed). However, the PCM will also pull timing a certain amount and then it will listen for knock. If it hears knock, it will pull more timing, but it will put it back if the knock goes away.
Right now, the only way I think it could be done is to have a set of injectors made that flow "x%" more than the stock injectors. This is a costly route for us, though, as injectors come in various sizes already that problem won't support a small change in flow. We could also try to figure out how to bump the fuel pressure. Fuel injectors are rated at something like 31psi of fuel pressure. If you run 50psi of pressure, the effective flow rate of the injector goes up. I can't find fuel pressure info on our SRT8s, so I will have to see if we have a schraeder(sp??) port on the fuel rail. If so, I have a fuel gauge I can stick on it. The next problem would be figuring out how to bump that pressure small amounts.
Edit: Okay, our fuel rail is bare. No test port. Our fuel system is a returnless system, so there is no easy way to boost the fuel pressure. I am going to have to crawl under the car to see if the fuel pressure regulator is internal to the pump(bad news, as then we have to pull the pump/regulator system to make any changes) or an external split right outside the tank(possible, but I doubt it). When GM went to returnless fuel systems, some of the hard core guys built simple return lines in after the line exited from the tank. The put a regulator in place and simple return line that just went back in the tank.
Todd
