Now your making me wonder if I should go out and richen my car, but then I'm running an 8:1 compression ratio so I should be safe running my 14:1 at idle.
When you get into the throttle you shoudl see that number drop. Lean cruise / idle is great ... just make sure the carb is setup up to deliver under full throttle the necessary fuel.marlinspike said:Now your making me wonder if I should go out and richen my car, but then I'm running an 8:1 compression ratio so I should be safe running my 14:1 at idle.
