1 - 15 of 15 Posts
My forum searches only found people with dealers replacing their radios whenever they have a problem with them.
But I really would rather not have the dealer digging in there, if at all possible...
My satellite radio froze about 2 weeks ago. When you switch to satellite radio is it stuck on the preview channel and none of the buttons work. No sound, nothing. But the regular radio, nav, and cd work fine.
I tried unplugging the battery for about an hour, but the radio seems to keep all the memory (doesn't loose pre-programmed radio stations or anything).
I would like to hard boot the satellite radio, but I can't find a way. Does anyone have any ideas how to do this?
TIA!
If you remove the left rear inside panel in the trunk, you can get to the Sirius unit. If you unplug the cable from it and run your car a bit, it will actually drop the saved stations and settings from the head unit. You can then plug it back it and it will force a download of the channel guide data. If that does not clear it up, you will need a trip to the dealer.
I had a Sirius issue a while back (lost all channels, even the preview channel). The dealer called DC directly and spoke to a technician who walked him through some things to do. One of the things he did was use a combination of the radio unit front panel buttons to reset the system. Unfortunately, I did not have a clear enough view to see all the things he was trying, but it involved using the INFO button while pressing some other buttons. The CD player spit out all the CDs in quick succession and the system reset. Anyway, it seemed to fix the problem.
I wish I could tell you the exact button combination. There must be a list somewhere of all the "special" button combinations somewhere. Anybody have any more info?
Mine just did this same thing.... I will try unpluging Sirius...I would rather not unplug battery....don't want to have to setup all electronics and such.
Funny, if we have M*soft in our cars, then we got real problems. Since you mentioned Ctrl-Alt-Delete, check out
www.spikedhumor.com/Article.aspx?id=1423
The expression on Bill Gate's face is hilarious!
The truth hurts doesn't it. Hey Mr. Bill, if you made a stable operating system in the first place, you wouldn't have a reason to get upset.
If that ctrl-alt-delete inventor still works for Microsoft, I'm sure it won't be for long.
Discussion Starter #11
I unplugged the battery for 1 hour, and nothing was lost. Nothing in the memory seats, radio, etc... Car drove just as usual afterward.
It worked for me
After my local dealer was clueless about how long a "hard reset" might take on a satellite radio and having to wait four days for an appointment I found this and tried it on my 2007 300C. I had to unplug both cables but it worked like a charm. Thanks JonW and 300C forum!
I just unplugged the cables and drove around about 20 minutes....plugged them back in and same ole stuff "P1 sat 184" and that is it......NO VOLUME....NOTHING!!!!:pat:
What next...a new satellite unit?? :dead1:
Uhm....maybe they did but doubt an answer is forthcoming as this thread was last posted in over 4 years ago...until today.
1 - 15 of 15 Posts
