AS it says, does any one know how strong these little V6s are could they handle
an extra couple of hundred horse power from a couple of little Turbo's ?
John.
That'll do it, then. Mostly mid to high range power with the turbo. Not much on the low end. You can go with a taller set of rear gears for a bit more torque at lower RPM.
Thanks MADDOG,
Not looking for big numbers just some bottom to mid range torque.
Cheers.
An extra coupla hundred hp isn't exactly "not" big numbers. :jester:
MADDOG,
2 Little ones with not much lag wouldn't that give you bottom end torque?
Peter2772000,
You can buy a set of different ratios gears for these cars ?
New I should of bought the SRT8 300 have got a change over price will loose to much in only 6 months, don't mind giving money away but no throwing it away. lol
Thanks Guys.
