looks to be about the same IMO.So is taking the rear bumper/fasia harder or about the same as taking of the front bumper to replace the grill?
I searched the whole website and internet! And I was just wondering? Is this the best information on how to take the bumper of or did I maybe miss something with more detail?Hemmissey,
This is the information directly from the LX Service Manual--
1) Remove the wheel house splash shield rivets. (3 per side) Get new rivets from dealer
2) Remove the fascia to quarter panel screws (1 per side)
3) Remove the deck lid bumper stops (2 for the sedan)
4) Remove the push pin fasteners (3 for the sedan)
5) Remove the fascia from the vehicle (Fascia is held on by several clips on both sides)
6) Disconnect the electrical connector and remove the fascia assembly
7) Remove Park Assist Sensors (If necessary)
PARK ASSIST SENSOR REMOVAL INSTRUCTIONS
1) Disconnect and isolate the negative battery cable (-)
2) Remove rear fascia (Refer to the above instructions)
3) Unsnap Park Assist Sensor from the retaining housing and remove from fascia.
PARK ASSIST SENSOR INSTALLATION
1) Position the Park Assist Sensor over the retaining housing and firmly snap housing
into rear fascia.
2) Install rear fascia (Refer to next set of instructions)
3) Connect negative battery cable and perform recalibration procedure
REAR FASCIA INSTALLATION
1) Install Sensors (If necessary)
2) Verify that the clips and push pins are secured into the fenders.
3) Place the fascia assembly into position and reconnect the electrical connector.
4) Install the fascia onto the bumper and slide the open fascia slots over the 4 push
pin fasteners
5) Install the push pin fasteners (3 per sedan)
6) Install the two bumper stops (Sedan Only)
7) Install the fascia to quarter panel screws and secure into the quarter panel.
8) Install the wheel house splash shield rivets
That's it!
Again, The splash shield rivets are designed to work one time only, replacements can be obtained from your dealer.
Hope this information helps.
Sincerely yours,
Brian T. Carotenuto
here's some more that may help. I don't think anyone did a writeup with pics, but with the info in the threads you have you should be able to get a good headstart. maybe take some pics as you go and do a write-up for the future folks like yourself?I searched the whole website and internet! And I was just wondering? Is this the best information on how to take the bumper of or did I maybe miss something with more detail?
Cool, because I think that is where my friggin' rattle is coming from.... once my wife gets back from some family issues in a week or so I'll ride around in the trunk again to make sure. Thanks for the update post brother!it's actually easier than the front..
