I understand what you are saying. The only thing I'm not sure about regarding what you said is the oil change monitor. Is this a feature in the EVIC? My original question in this thread (which has already been answered) was regarding the "reminder" that pops up at 6K miles, but I'm not aware of how to check the "oil monitor" in the EVIC. Maybe it just wasn't clear from your reply, but I don't think the reminder takes into consideration the actual condition of the oil. I changed my oil at 600 miles, and then did it again on the 3000 mile intervals. It wasn't until I got close to 6000 miles that it started reminding me, and before that happened I had already done 2 oil changes. I think this is just a reminder that triggers every 6000 miles, so you are probably right that the factory will honor my warranty so long as I do the changes on 6000 mile intervals, especially since the manual says do the changes every 3000-6000 miles. They have no way to prove how I drive my car or how long or short my trips are.
Exactly, the oil change interval monitor on the car says 6000miles or close to that, so why change it earlier? There is no way that you engine will need to be changed that frequently. And even though you do some sprorted driving and some short trips, don't consider your driving to be severe seeing one decent drive with it will drive off and evaporate any fuel in the oil from a couple short trips. And with outside temps going up with summer, there really isn't any short trips.
How much does it cost to get the oil analysis done? Probably less than I'm spending on extra oil changes, if they are unnecessary. Maybe I will do the change somewhere in the middle next time (say 4500 miles), and send an oil sample in for the analysis. I will be doing it for myself though, not to "prove your point"
Great to hear! BlackStone labs will send you a free kit that you can use to sample the oil. Trust me, it will show exactly what is going on with your engine. I would wait till 15000miles though so you engine can break in. If you do it now, the oil anaysis will show high silicon, iron, Nickel and copper which is perfectly normal for an engine wearing in. They all drop off to nothing once the engine is broken in.
I would do it just to prove me wrong, I am only out to save you money and still get the amazing protection from your oil seeing even at 6000miles, the oil will still have minimum 20% active additive left and oil that is still is perfect condition.
I read through lots of discussions in the "Synthetic" thread last night to try to figure out what people are doing and it does sound like most people are changing their synthetic less frequently than the 3000 mile intervals I'm doing. One person said that the oil filter should be changed at least twice a year. Obviously the filter should be replaced when the oil is changed, but it sounded like he was saying that there may be some benefit to changing the filter even if you don't change the oil, but that doesn't seem right to me.
For a $5 filter, I change the filter always with the oil. To some the filter will help. But if you get a good filter, a clean engine will never plug it up within 6000miles to put the filter into bypass mode.
Make sure you use a Wix or Purolator filter and never use a basic junk fram filter. The only Fram to use is the Fram XG (Xtended Guard) which is the one i use seeing it uses synthetic fiber media and a nice silicon anti-drainback valve which keeps the oil from draining back down into the oil pan. The ADBV keep oil in the top end seeing it will be there for instant lubrication when you start the engine up.
Essentially killing any startup clatter.
Ignorance is the condition of being uninformed or uneducated, lacking knowledge or information.
I'm defintely uninformed and lacking knowledge when it comes to oil, and that is why I'm here in this forum, so I guess by that definition I would be considered ignorant. I'm not uneducated though. I have two Bachelor of Science degrees, one in Computer Science and another in Mathematics and graduated Magna Cum Laude. I may be ignorant when it comes to oil, but I'm not ignorant. Do you see my point?
If you look at your definition above, it is uninformed OR uneducated, not uninformed AND uneducated. I was talking strictly about oil. But seeing you are learning quickly, I don't think it applies to you anymore. You are seeing the benfits of synthetic and I think you are realising the true potential of synthetic.
The problem is that words like ignorant do sound offensive. Would you tell your manager he is ignorant because he cannot understand the technical details of what you do at work? No. You would simply educate him on the topic until he understands the problem (or solution) and move on with your work. My point is that this is just the wrong choice of words to use on this forum. No matter how much you know about a topic, it is best to not have a condescending attitude toward other forum members. When you know something that someone else doesn't, it is best to be humble, and give them the information they need to understand the topic.
I never had an attitude at all and I used a word that in some weird reason people think means rude. I guess some are ignorant about the meaning of ignorant.:biggrin: just kiddin'
Keep on learning about synthetic, and if you want a BOAT LOAD of info, this is the best place in the world.
Bob Is The Oil Guy - Powered by Motor Oil:fing02:
