I was wondering how do you turn off the check engine light without going to the dealer. My light came on as a results of the gas thing and now it won't go off. It's been a couple of weeks and I'm tired of looking at this light so does anyone know how to turn it off.Thanks
pull fuse 11...
I have made this suggestion before elsewhere and got somewhat villfied for it...
as you should really get in into the the dealer to check out why...
my issue is a reoccuring O2 sensor issue that is loose...
you can dod a search and find the thread on this...
fuse 11 is in the front fuse box...
pull the fuse while car is off...
put back in after 15-20 seconds...
some say a minute...
if you want to stand around for a minute be my guest...
15-20 seconds works...:wink:
and turn the car back on...
it should work...
FYI - there has been several others lately with the same problem...
so don't make the assumption it is the gas issue as there are 3-4 things it could be in dealing with it...
GOOD LUCK!
Sincerely,
i think you can disconnect the battery also and it will do the same as pulling fuse # 11 just an alternative if it comes back on i would see what fault codes you are getting hopefully it will only be a reset.
i did the 8000K foglights. I will have to change my headlights to 8000K because my factories aren't as bright as the fogs.
My car is an SRT8.
The dealer installed the O2 sensor. My Check engine light came back on when I did a hard acceleration so I'm gonna have the code checked.
