i have been looking at wheels some new some used online and I can find alot but need to know the hub size in the middle of the wheel also the offsets used for 20 and 22 inch wheels
also if anyone knows for sure is the bolt pattern 5x114.3 or 5x115 please any info will help
5x115 is correct. I state this from numerous postings; unfortunately, I can't verify with a reference to the service manual (couldn't find it! even though it most be in those thousands of pages).
If you do a search for "114.3" (you can't use 115 because it is too short for this site's search engine to recognize) you will see several threads dealing with this topic. I think the consensus of those postings is:
1) 115 is correct but much harder to find
2) 114.3 will phsically fit; but, problems are possible
As far as the offset, this site has such numerous opinions that I can't sort through them to offer anything close to a consensus. I am sticking with the O.E.M. wheels so I have just giving past postings superficial interest....because of this, trying to do a quick study is not possible due to the overwhelming number of opinions. If you spend a good bit of time researching you will probably be able to sort through the junk and find the gold....good luck.
Bolt Pattern is 5x115 & bore size is 71.6mm
