I hope so.Good show, keep winning streak going. You should have a good runner when done.
Will pick up some mineral oil then, nothing fancy for the short period I intend to run it in."Maybe I should use a running in oil? "
Don't think your gaining by using synthetic for such a short period. Conventional and synthetic are compatible, so no worries about residual after a change. If the savings is sufficient, then doing so is fine IMO.
I've heard a lot about Marvel Mystery Oil but can't recall ever seeing it in Australia. Might try to track some down."the "red" HOAT coolant is what I want... "
There's a product here in the state called Marvel Mystery Oil. Honestly, I use it cause Grandpa did. He insisted that my father use it at every oil change and now I do also. I even keep a bottle in the boot and put a few ounces in the tank when gassing up. If it's available by you and not too costly... it's brought me good luck thru the years and surely couldn't hurt![]()
Video is gold. I'd like to work out why that front clip doesn't quite fit on my car and that helps a lot!"...if I can work out how to get it out! "
Simple enough...
two bolts & unplug the fan assembly. Tilt back & lift up...
edit to add: Just recalled your front bumper cover is still on. It needs to come off, Two small screw up into the fender on each side, and the screws to the lower splash cover...some xmas tree plugs.... very quick process. Set some cardboard down, lay it back to unplug the lights...
