Hello I’m new to the Chrysler thing, I have a 2005 Chrysler 300c, it runs for about 5 seconds and then dies unless you give it gas to keep it running. Guy I got it from put a new used motor and said he also had done the internals. Factory computer was flashed and reprogrammed nothing changed guy but a new computer and had it programmed to the car at Chrysler and still nothing changed. Pulled injectors and they all sprayed didn’t check with a gauge tho, said it throws a code saying “vin mismatched” he said he took it to Chrysler had it fixed and then after a few days of messing with it, it was there again. Ran compression test on all cylinders and they read where they were supposed to. Said he hadn’t got to replacing the crank sensor but he did have a new one for it. He said he replaced most if not all the regular sensors you would normally check for and nothing seemed to change along with coil packs and plugs. Haven’t personally got to tinker with it myself yet but figured I could hop on here and maybe find a place to start.
