1 - 1 of 1 Posts
BREAK THRU PERFORMANCE DELIVERED BY NEW GENERATION TWIN SCREW SUPERCHARGER;
RICHWOOD'S INTEGRATED SUPERCHARGER, THE " I-CHARGER".
FEATURES;
Unique Patented Inverted design
Compact, lightweight, highly efficient one piece housing
Open free flowing port runners for max torque
Latest highly efficient twin screw rotor design
Highest internal compression on the market, translates into crisper, cleaner response and reduced discharge temps
Boost range from 6 psi thru 25 psi
Open free flow intake bonnet for max incoming air
Integrated by-pass valve for part and no throttle response, no parasitic loss
Instant boost / horsepower and torque and any rpm
Maintenance friendly design for ease of access to all components
Larger bearings and shafts for ultimate longevity
Lower noise levels
Up to 98% efficiency
Self contained oiling system
Direct bolt on, fits under the stock hood
50 state legal pending
TUNING
Direct Port Injection via 8 larger injectors on the rail and 2.25 bar map sensor
Pre-programmed hand held tuner with easy 1 step tuning
No Wiring Required, completely plug and play
Optional tuning code to program high boost or off road applications
OPTIONAL EXTRAS;
Two stage water to air intercooler
Big bore billet throttle body
Cold air intake
Phenolic anti-heat transfer spacers
Boost upgrade from 6lb thru 25lb.
High boost Dual injector models
Big bore oval throttle body intake bonnet
Complete engine packages to suit your boost requirements
Billet heavy duty drive line components to suit your added horsepower demands
JOIN THE REVOLUTION !!!
CONTACT PAGE FOR MORE INFORMATION
Contact [email protected]
1 - 1 of 1 Posts
