1 - 20 of 74 Posts
Cruise Indicator it's the one thing I wish they would of put in the driver
information cluster, when in use of course
:blackeye:
Yeah, I commented to my wife when we were on a trip that it was strange there was no indication when cruise was active.
I read in a local magazine roadtest where they had a swipe at the "hard to see" cruise control light on the stalk. When I tried to defend the 300C having the set up it does and that is doesn't really matter she was quick to point out my bias. Whoops :(
information cluster, when in use course
:blackeye:
I miss that too. I don't know why. The little yellow light on the stalk tells you the cruise system is on but another one would remind you that it is activated and that you may need to tap the brakes to slow down for slower traffic or turns.
I may be mistaken, but don't we have a little speedometer icon displayed when the cruise is engaged? I have not used it too often, but I'm almost certain I get a little lighted icon when I set the speed on my cruise. The LED on the stalk activates when I turn on cruise. The icon lights when I set a speed.
Can anyone confirm? I'll check tomorrow.
Bus Rydr, (BTW I like your handle :fing02:), definitely no Icon on my 300C. If you have one I want one too.:15:
I also have an icon to the bottom left of my speedometer that indicates when the cruise control is on.
Just used it tonight.......
BB42
Okay, you guys gave me a reason to go ride around the block (like I really needed a reason to drive C)
I was only partially correct. When I turn on Cruise, I get the amber LED on the stalk and a green icon of a speedometer on the left side of the instrumentation cluster. Also "Cruise On" is displayed for a few seconds in the EVIC. When I set the speed, "Crusie Set" is displayed for a few seconds. While Cruise is on, the only display (speed set or just on) is the amder LED on the stalk and the green icon.
Now that I look at it, it would have been nice to have the icon display only when a speed is set or keep the "Cruise Set" displayed while the speed is set.
But, we do have the option to set cruise.....
This is the Bus that I ride (Suzuki HayaBUSa.. The Hemi of motorcycles)
hmmm
This feature must be in the later 2006 300s. Mine was built april 2005 and definitely has no icon or anything else to show me that cruise is being engaged.
Jaydee
Not on Mine
Jaydee
It is not on mine either. There is no icon shown in the owners manual either. Bob.
Mine was built in 6/05. Can the icon be added by Starscan at the dealer or is it a hardware issue? I'd sure like it. The yellow light on the stalk is really hard to see behind the wheel. Bob.
6/04 build, no icon here. Often it's these little things like the Aux. audio jack, better tires, etc. that show up on the next year's model. One reason to wait until the second year to purchase which is what I'll do with my Challenger/Camaro decision.
Discussion Starter · #12 ·
:yell: CALLING Starscan experts :33:
wait a minute
Okay so today I went over the icons again- right next to the gas icon, on the left side is something that I can vaguely see as a circular icon with radial graduations on it though I cant make out if there is one longer arm on one of the radial spokes... This light does NOT (on edit)come on in self test mode. Wish someone would take up the challenge and see if this is starscan enable-able if the icon is present..
Jaydee
jaydee said:
Okay so today I went over the icons again- right next to the gas icon, on the left side is something that I can vaguely see as a circular icon with radial graduations on it though I cant make out if there is one longer arm on one of the radial spokes... This light does come on in self test mode. Wish someone would take up the challenge and see if this is starscan enable-able if the icon is present..
Jaydee
I'll check it next opportunity.
Jaydee
I sure hope someone can solve the mystery soon. I called my Service manager and he is still trying to find out from his technical contact at DCX. Bob.
BobF said:
I sure hope someone can solve the mystery soon...
I'll have a starscan on mine by Tuesday. If it can be enabled on an '05 and the early '06s we'll all know soon.
I for one will be anxiously awaiting your information. It sounds like it may be a hardware issue with the cluster configuration and not just a software issue. Regards, Bob.
And while you're looking, see if you can keep the "Cruise Set" display in the EVIC on constant as long as the cruise speed is actually set. Currently, it displays only for a few seconds, then reverts back to displaying the trip reading.
If we can get the instrument panel light to illuminate like the later '06s do this would be overkill, IMO.
Will ask the question, tho'.
1 - 20 of 74 Posts
