Below are the TSB's on the 300 issued as of June 13th. It appears none issued for over a month, a good sign. These should not apply to anything built after May 1.
Wonder what the "Launch Fast Feedback Program" is?
Make : CHRYSLER Model : 300 Year : 2005
Service Bulletin Num : 2100604 Date of Bulletin: APR 27, 2004
NHTSA Item Number: 10006886
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
SHUDDER DURING SHIFTS. ALSO DODGE MAGNUM 2005. *TT
Check to Request Research. Submit below.
Service Bulletin Num : 04009 Date of Bulletin: APR 16, 2004
NHTSA Item Number: 10006905
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
APPROXIMATELY 260 VEHICLES EQUIPPED WITH A 5.7L ENGINE WERE SHIPPED WITH INCORRECT ENGINE SOFTWARE IN THE POWERTRAIN CONTROL MODULE (PCM) THAT RESULTS IN NON-COMPLIANCE. IT WILL BE NECESSARY TO REPLACE THE PCM. *TT
Service Bulletin Num : 0410 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10006997
Component: POWER TRAIN:AXLE ASSEMBLY
Summary:
REAR AXLE NEW LAUNCH FAST FEEDBACK PROGRAM FOR ALL 2005 CHRYSLER 300 SERIES AND DODGE MAGNUM VEHICLES. *TT
Service Bulletin Num : 0405 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10007046
Summary:
NAG1 TRANSMISSION EQUIPPED VEHICLES WILL BE INVOLVED IN A STAR CENTER TRANSMISSION NEW LAUNCH FEEDBACK PROGRAM. WARRANTY PLANNING & ADMINISTRATION BULLETIN. *TT
Service Bulletin Num : 0406 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10007047
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
NEW LAUNCH FAST FEEDBACK ENGINE PROGRAM. WARRANTY PLANNING & ADMINISTRATION BULLETIN. *TT
Service Bulletin Num : 0801204 Date of Bulletin: MAR 23, 2004
NHTSA Item Number: 10006456
Component: ELECTRICAL SYSTEM
Summary:
LOSS OF COMMUNICATION DIAGNOSTIC TROUBLE CODES (DTC'S) SET IN MULTIPLE MODULES DURING NEW VEHICLE PREP/SERVICE. *TT
Service Bulletin Num : 0801304 Date of Bulletin: MAR 23, 2004
NHTSA Item Number: 10006457
Summary:
RECALIBRATION PROCEDURES REQUIRED AFTER BATTERY DISCONNECT. 2005 CHRYSLER 300M. *TT
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
