1 - 20 of 26 Posts
Hey guys, I decided to start a new thread for my 2015 300S Interior LED conversion because many of the bulb types and bulb locations I reviewed have changed since the older LED threads were posted.
Additionally, I specify "Interior" conversion because on MY15, most, if not all the exterior bulbs (Fog Lamps/License Plate Lamps/Side Mirror Indicators/DRL's) are already factory LED's, and nice white ones at that. ::wink::
Interior LED Type/Quantity Listing: (All 2015 & 2016 300 models have the same bulb styles and quantity)
Trunk Lamp - 2 x 44mm Rigid Loop Festoon (AKA Type 561/562/563/567/ 564/566/570)
Rear Door Puddle Lamps - 2 x 44mm Rigid Loop Festoon
Front Door Puddle Lamps - 2 x 44mm Rigid Loop Festoon
Rear Map/Dome Lamps - 2 x T10 Wedge Bulb (AKA Type W5W/168/194/921...etc)
Front Map/Dome Lamps - 2 x T10 Wedge Bulb
Glove Box Lamp - 1 x T10 Wedge Bulb
Visors/Vanity Mirrors - 4 x 29mm Fuse Shape (6641) Bulbs
The LED Bulbs I Used - Total Cost $39.56 (Includes 15 EXTRA bulbs):
10 x Super White 44mm 5050 6 SMD Rigid Loop Festoon Door Map LED Light 561 562 | eBay
10x T10 White High Power 5630 6 SMD Interior Reverse LED Light Bulb 921 912 906 | eBay
10X High Power 5630 LED Bulbs Sun Visor Vanity Mirror Light Fuse Shape 6641 29mm
Let's just say I am LED obsessed...:angel: I've been successfully swapping/converting automotive bulbs for about 12-years now across many makes of vehicles owned and in the family including Jeep, Scion, Infiniti, Hyundai, Lincoln and now Chrysler. I will say a lot has changed for the better in LED technology over these years, and I have learned a lot through trial and error spanning countless brands, bulbs and LED styles.
That being said, for the most part I no longer support the "Big Guys" such as V-LEDS, Diode Dynamics, Autolumination, DDM Tuning, SuperBrightLeds, etc. for several reasons. #1 They are OVERPRICED. #2 They are often still pushing OLD LED technology. #3 Their bulb quality/reliability are FOR THE MOST PART no better than REPUTABLE, TOP-RATED eBay wholesalers. In many cases I would even suspect the big guys are using the same wholesalers that you can deal with directly without the markup based on IDENTICAL bulbs I have received.
So there's my background rant, and my personal experiences, the choice is yours..... I do have a list of trusted go-to eBay suppliers, so feel free to hit me up via PM or on the thread for LED suggestions or any install questions/problems. :nerd:
*** Before & After pictures will be uploaded as soon as I get through installation ***
Any luck with the lights in the overhead console?
Yeah, sorta :serious: The front overhead console has one T10 wedge bulb on each side as well as (as far as I can tell) one sealed LED from the factory.
I swapped out the wedge bulb with the LED's previously listed, the lens is a bit tricky to remove/loosen, but I didn't need to get it all the way off to do swap.
So the end result is full LED console, but unfortunately the stock sealed LEDs are much warmer/yellow in color than the ones I used for everything else. I'll post a picture next time I remember.
I just purchased a complete set of LED for my 2015 300s from Car-ID. Seems like I payed way more than the one's you have listed and not even sure if they will be the right ones. The first set they sent was not the right fit. Question, how did you replace the Map lights, did you completely remove the plastic cover from the front doom light cover. It seems it won't come completely off and had a difficult time reaching the map bulbs.
Discussion Starter · #6 ·
Sorry for the late reply....
Yup, that is the price you pay not going the eBay route $$$ ::wink::
Front map lamp lens is a bit tricky to remove/loosen, but I didn't need to get it all the way off to do swap. I have also seen some people use a piece of clear tape to grab the stock bulb and pull it out. Much easier getting the new LEDs back in.
Your Lights are looking real good job. With that said I just bought the 2014 300 C it has the daytime LED lights but the headlamp is just too yellow for me. I was thinking about switching it to HID but I am clueless about these things. Any advice or suggestions on which ones I should get.
Also, there is a performance shop close to my house so I asked the owner for suggestions and he said he wouldn't recommend HID for doge and Chrysler because they use a different voltage and the HIDs don't last long on them. He told me go with PIAA which isn't as bright or blue but then they wont give me any issues.
Discussion Starter · #12 ·
Bump for a bunch of recent PM's - Keep this thread handy :)
Does the Aussie SRT variant for 2016 onwards have the same lighting setup?
I just want to change the colour of some of my interior lighting, particularly the door puddle lamps, either blue, pink or purple. Maybe the glovebox and trunk lamps, not fussed on changing the map lights in the overhead console or the visor vanity lamps.
What about the small ambient LED lights at the door handles and just above the door drink holders. And also the ambient lighting in the front footwells. Are they changeable? If not what is a good alternative way to change the ambient lighting colour to something funky?
Discussion Starter · #14 · (Edited)
I'm sure it's the same lighting.
Ambient LEDS @ door handles, cup holders, footwells, front map lamps are not removable bulbs as they are factory LED's. Changeable, sure if you are good with a soldering iron. Not worth the trouble IMO.
Ah ok. Also the SRT Core model here in Australia doesn't have rear door puddle lamps. The clear plastic cover & hole is there but there's nothing inside.
I wonder if they're easy enough to install?
No simpler solutions to date for changing out the 3 factory LEDs in the overhead console? I just picked up a '17 base 300. Excuse my ignorance, but none of the latest, higher trim level cars come with a white or cleaner interior lighting setup? Do any other models share this overhead console with different lighting? I'd hate to mix and match the white with the awful yellow.
2015 300S AWD Maximum Steel currently 01/2022= 19,300 miles
Was just viewing this thread again because I now need another set of bulbs for the new ride and needed the ebay info & bulb numbers.
So, saw your post along w/few other guys not liking the overhead permanent bulb color, especially mixed with new white or blue LEDS.
When I did the conversion on my previous 300S, I changed out the overhead console bulbs and what I did to eliminate the small yellow/gold fused in bulbs was to use metal/foil HVAC adhesive backed tape. I cut several small squares, stacked them to make a thicker material, and applied it to block out that light. worked great. Gonna do same thing on the new 300 too.
mark~
mark~
Mark,
What I ended up doing is I just placed some blue window tint over the LEDs in the overhead console and also the footwell lights (they are the same, soldered on type). I think I used 30% blue tint, and it's more blue than I'd have liked, but it looks much better than before and I'm content with it. At this point, I've become accustomed to seeing the blue to where I don't even notice it really. If I were to do it again, I'd choose a thinner tint (the kind I bought is actually pretty thick) or maybe a 45-50% tint in the same thickness. It was like $3 shipped from eBay.
I ended up using some ice blue leds off of Amazon. Cost about $25 for all the lights. Included all interior, exterior and trunk. I like that they match the dash lights. For the soldered map lights I just taped over with electrical tape. You cannot even see it.
Hi,
Thanks for posting pics... those look really nice, and bright. when you get a chance, can you either post here or DM me a link to the Amazon lights you used? I had blue LED puddles on my 1st 300S and also really liked how they matched the dash lighting, but they werent as bright as i wanted.
I havent bought any bulbs yet for the new car and will def be doing all of them inside car and trunk lights. As we both mentioned here, I will once again just tape over the 2 small warm light bulbs overhead.
TIA, mark~
BTW: will update avatar to new ride if it ever gets warm and clear of salt outside again to get some clean pics of the car :)
1 - 20 of 26 Posts
