HELP!! Is this a good deal for a 12'' JLW7?
Went to Pacific Stereo today and they quoted me for the 12'' JL Audio W7 in the box, with the Almani Chrome 950W Amp, Dynamat, Speaker Cables, and Labor all for $1000 flat.. Is this a good price? Let me know if I should go with it.. Thanks!!
JL W7 12'' in enclosure made from the specs of JL
I'm sure you know the specs and quality for the W7's.. but will this amp work?
Item Number: ALC950
2 Channel 950W, Digital High Power Amplifier
4 [email protected]% THD (20Hz-30kHz): 150W X 2
2 [email protected]% THD: 300W X 2
4OHMS BRIDGED 1% THD: 600W X 1
MAXIMUM OUTPUT POWER: 950 WATTS
LOW PASS FILTER: (VARIABLE) 50Hz-250Hz
HIGH PASS FILTER: (VARIABLE) 80Hz-1.2kHz
FREQUENCY RESPONSE (-1dB): 10Hz-40kHz
SIGNAL TO NOISE RATIO ('A' WTD): >100dB
INPUT SENSITIVITY: 200mV Ohms - 6V
INPUT IMPEDANCE: 22k Ohms
OPERATION VOLTAGE (NEGATIVE GROUND): DC 12V
SPEAKER IMPEDANCE @ STEREO DRIVEN: 4 Ohms
FUSE RATING: 30A X 2
DIMENSIONS (W X H X D): 287 X 57.5 X 325
Item Number: ALC950
