I don't think it is in the manual, Joey posted a diagram from the shop manual. I have had mine on 4 jack stands, best yo use the diagram. I jacked the entire side from the front subframe and placet the rear at the rocker jack point and the front stand under the subframe next to the hydraulic jack. Best to search jacking points, a question posed by me, it shows the diagram.
jjs said:
Isn't that info in the manual?
If not there, it defintely is in the service manual. I would cut and paste the info; but, I can't....that function doesn't work on my pdf file. Does it work for anybody?
· Premium Member
If this is what you are referring to...
http://www.300cforums.com/forums/attachment.php?attachmentid=4383
is states to refer to the owner's manual...
mine is at home right now or I would check...
