1 - 18 of 18 Posts
I recently had the pleasure of viewing the latest episode of Top Gear, an automotive show on the BBC from the UK. Unfortunately Discovery channel neglected to pick up this season, so the only way to watch these episodes is through the internet. In the most recent episode, Jeremy Clarkson had the privilage of racing a Cessna Airplane in a Bugatti Veyron 16.4 from Italy to London. Guess who won?
High resolution photos of the ones below are here
Specifications
Engine
Type: W16, Quad-Turbocharged
Displacement cu in (cc): 488 (7993)
Power bhp (kW) at RPM: 1001(736) / 6000
Torque lb-ft (Nm) at RPM: 923(1250) / 2200-5500
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 245/690 R520 - 335/710 R540 (PAX System)
Driveline: All Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: 174.2 × 77.9 × 47
Weight lb (kg): 4162 (1890)
Performance
Acceleration 0-60 mph s: ~ 3
Top Speed mph (km/h): 253 (406)
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
Base Price: 2006 Bugatti Veyron 16.4 - Approx. $1,700,000 (last update: 11/1/2005)
Utterly, stunningly, jaw droppingly brilliant
By Jeremy Clarkson of The Sunday Times
When you push a car past 180mph, the world starts to get awfully fizzy and a little bit frightening. When you go past 200mph it actually becomes blurred. Almost like you’re trapped in an early Queen pop video. At this sort of speed the tyres and the suspension are reacting to events that happened some time ago, and they have not finished reacting before they’re being asked to do something else. The result is a terrifying vibration that rattles your optical nerves, causing double vision. This is not good when you’re covering 300ft a second.
Happily, stopping distances become irrelevant because you won’t see the obstacle in the first place. By the time you know it was there, you’ll have gone through the windscreen, through the Pearly Gates and be half way across God’s breakfast table.
It has always been thus. When Louis Rigolly broke the 100mph barrier in his Gobron in 1904, the vibration would have been terrifying. And I dare say that driving an E-type at 150mph in 1966 must have been a bit sporty as well.
But once you go past 200mph it isn’t just the suspension and the tyres you have to worry about. The biggest problem is the air. At 100mph it’s relaxed. At 150mph it’s a breeze. But at 200mph it has sufficient power to lift an 800,000lb jumbo jet off the ground. A 200mph gust of wind is strong enough to knock down an entire city. So getting a car to behave itself in conditions like these is tough.
At 200mph you can feel the front of the car getting light as it starts to lift. As a result you start to lose your steering, so you aren’t even able to steer round whatever it is you can’t see because of the vibrations. Make no mistake, 200mph is at the limit of what man can do right now. Which is why the new Bugatti Veyron is worthy of some industrial strength genuflection. Because it can do 252mph. And that’s just mad — 252mph means that in straight and level flight this car is as near as makes no difference as fast as a Hawker Hurricane.
You might point out at this juncture that the McLaren F1 could top 240mph, but at that speed it was pretty much out of control. And anyway it really isn’t in the same league as the Bugatti. In a drag race you could let the McLaren get to 120mph before setting off in the Veyron. And you’d still get to 200mph first. The Bugatti is way, way faster than anything else the roads have seen.
Of course, at £810,000, it is also jolly expensive, but when you look at the history of its development you’ll discover it’s rather more than just a car . . .
It all started when Ferdinand Piëch, the swivel-eyed former boss of Volkswagen, bought Bugatti and had someone design a concept car. “This,” he said, “is what the next Bugatti will look like.” And then, without consulting anyone, he went on. “And it vill have an engine that develops 1000 horsepower and it vill be capable of 400kph.”
His engineers were horrified. But they set to work anyway, mating two Audi V8s to create an 8 litre W16. Which was then garnished with four turbochargers. Needless to say, the end result produced about as much power as the earth’s core, which is fine. But somehow the giant had to be cooled, which is why the Veyron has no engine cover and why it has 10 — count them — 10 radiators. Then things got tricky because the power had to be harnessed.
For this, VW went to Ricardo, a British company that makes gearboxes for various Formula One teams.
“God, it was hard,” said one of the engineers I know vaguely. “The gearbox in an F1 car only has to last a few hours. Volkswagen wanted the Veyron’s to last 10 or 20 years. And remember, the Bugatti is a damn sight more powerful than any F1 car.”
The result, a seven-speed double-clutch flappy paddle affair, took a team of 50 engineers five years to perfect.
With this done, the Veyron was shipped to Sauber’s F1 wind tunnel where it quickly became apparent that while the magic 1000bhp figure had been achieved, they were miles off the target top speed of 400kph (248mph). The body of the car just wasn’t aerodynamic enough, and Volkswagen wouldn’t let them change the basic shape to get round the problem.
The bods at Sauber threw up their hands, saying they only had experience of aerodynamics up to maybe 360kph, which is the effective top speed in Formula One. Beyond this point Bugatti was on its own.
Somehow they had to find an extra 30kph, and there was no point in looking to the engine for answers because each extra 1kph increase in speed requires an extra 8bhp from the power plant. An extra 30kph then would need an extra 240bhp. That was not possible.
The extra speed had to come from changing small things on the body. They started by fitting smaller door mirrors, which upped the top speed a bit but at too high a price. It turned out that the bigger ones had been keeping the nose of the car on the ground. Without them the stability was gone.
In other words, the door mirrors were generating downforce. That gives you an idea of how much of a bastard the air can be at this speed.
After some public failures, fires and accidents, and one chief being fired, they hit on the idea of a car that automatically changes shape depending on what speed you’re going.
At 137mph, the nose of the car is lowered by 2in and the big rear spoiler slides into the slipstream. The effect is profound. You can feel the back of the car being pressed into the road.
However, with the spoiler in place the drag is so great you’re limited to just 231mph. To go faster than that you have to stop and insert your ignition key in a slot on the floor. This lowers the whole car still further and locks the big back wing down. Now you have reduced downforce, which means you won’t be going round any corners, but you have a clean shape. And that means you can top 400kph.
That’s 370ft a second.
You might want to ponder that for a moment. Covering the length of a football pitch, in a second, in a car. And then you might want to think about the braking system. A VW Polo will generate 0.6g if you stamp on the middle pedal hard. You get that from the air brake alone on a Veyron. Factor in the carbon ceramic discs and you will pull up from 250mph in just 10sec. Sounds good, but in those 10sec you’ll have covered a third of a mile.
That’s five football pitches to stop.
I didn’t care. On a recent drive across Europe I desperately wanted to reach the top speed but I ran out of road when the needle hit 240mph. Where, astonishingly, it felt planted. Totally and utterly rock steady. It felt sublime.
Not quiet, though. The engine sounds like Victorian plumbing — it looks like Victorian plumbing as well, to be honest — and the roar from the tyres was biblical. But it still felt brilliant. Utterly, stunningly, mind blowingly, jaw droppingly brilliant.
And then I reached the Alps where, unbelievably, it got better. I expected this road rocket to be absolutely useless in the bends but it felt like a big Lotus Elise.
Occasionally, if I accelerated hard in a tight corner, it behaved strangely as the four-wheel-drive system decided which axle would be best equipped to deal with the wave of power. I won’t say it’s a nasty feel or dangerous. Just weird, in the same way that the duck-billed platypus is weird.
You learn to raise an eyebrow at what’s only a foible, and then, as the road straightens out, steady yourself for Prince Albert’s boiler to gird its loins and play havoc with the space-time continuum. No, really, you come round a bend, see what appears to be miles and miles of dead straight road, bury your foot in the carpet and with a big asthmatic wheeze, bang, you’re instantly at the next bend, with your eyebrow raised again.
From behind the wheel of a Veyron, France is the size of a small coconut. I cannot tell you how fast I crossed it the other day. Because you simply wouldn’t believe me. I also cannot tell you how good this car is. I just don’t have the vocabulary. I just end up stammering and dribbling and talking wide-eyed nonsense. And everyone thinks I’m on drugs.
This car cannot be judged in the same way that we judge other cars. It meets drive-by noise and emission regulations and it can be driven by someone whose only qualification is an ability to reverse round corners and do an emergency stop. So technically it is a car. And yet it just isn’t.
Other cars are small guesthouses on the front at Brighton and the Bugatti is the Burj Al Arab. It makes even the Enzo and the Porsche Carrera GT feel slow and pointless. It is a triumph for lunacy over common sense, a triumph for man over nature and a triumph for Volkswagen over absolutely every other car maker in the world.
Verdict: Deserves 12 stars. Simply as good — and as fast — as it gets
· Premium Member
I watch the show almost every week... the only thing I don't like is the hatred of all things american, at least that's what it seems like when he talks about an American car.
Otherwise, a good show. Plan on trading my 300 in on the bugatti..... I wish. Outstanding automobile!!
The January 2006 issue of Road & Track has a big spread on the Veyron, too, including a technical analysis by Gordon Murray. Muray designed the McLaren F1, one of the greatest supercars of all time. Predictably, Murray finds the Veyron to fall short of the McLaren as the ultimate road car because of its weight and turbo lag, but considers it "... a massive technical achievement-a statement for VW AG. And it will be guaranteed a place in automotive history because of the performance figures."
BTW, if you like Top Gear, you'll also probably like Fifth Gear on Speed TV, which is a pretty similar show with the same cast. I personally can't get enough of Vicki Butler-Henderson:
who's bright, cute, has a sexy British accent, and above all is a bonzer car gal.
Rick
Northern Rider said:
Bonzer, eh - Rick? I love the show too.
Rogue, the burning question about the Veyron is still unanswered. Readers want to know -
"How many cupholders does it have?"
Cupholders? ....We don' need no steenkin' cup-holders
It's amazing how pussyhurt some of you guys get over them poking fun at the US and US cars. If you haven't noticed next to nothing is sacred on that show which is one of the very best and most entertaining draws of it.
· Premium Member
Actually, I don't really care.... just the only thing I don't like about his show. I hate European cars, they are too utilitarian in the inside and over-hyped, so I'd probably be the same way if I had my own show. But I don't know how much British TV you watch, but sometimes its hard to believe they are our friends by the way the UK media talks about the US. SO there :)
HEMEEE said:
WOW! What a machine... and "jolly expensive" is bloody right!! :hypnotize
As expensive as £810,000 may sound, and at this time of night i'm not capable of the £/$ math, Clarkson also pointed out that each vehicle will cost VW, including development costs, an amazing £5,000,000 to build.
Former VW boss, and Bugatti owner Ferdinand Piëch simply wanted to show the world what they are capable of, and good on him.
Sometimes, when you listen to our media, you would think we hate ourselves. Maybe the rest of the world's media takes cues from our own. That car is really something else. It accelerates like a Fuel car, it stops like a 300 SRt-8 (only from much greater speeds), and it has a higher top speed than any other street car, and most all but the fastest of race cars. And, to boot, it has one of the plushest interiors available in anywhere but Ted Turners toilet room. I love our cars. I was driving a friend of mine from the golf course the other day, and had the need and opportunity to pass an immigrant, and the acceleration from 50 to 100mph is astonishing, as most of you know. He was speechless. He's been in on some heavy accelerating, but that was shocking to him. I love it.
I Had The Pleasure Of Spending The Day At A Track With The Top Gear Crew, Just A Hadfull Of Us, These Guys Are Nuts, Really Fun Too, Look For The Show Comingup Where They Drove 3 ****boxed From Miami To New Orleans, I Should Be In It
"Somehow they had to find an extra 30kph, and there was no point in looking to the engine for answers because each extra 1kph increase in speed requires an extra 8bhp from the power plant. An extra 30kph then would need an extra 240bhp. That was not possible."
So tuners can get over a 1000 WHP out of a 6 CYL engine they can even get 988 WHP out of the EVO engine a 4 banger, and yet they couldn't get an extra 240 BHP out of an 8L 16 CYL Quad Turbo Engine.
I have a friend here locally who got to test drive one...
not at 240 though...
not even 150...
although, he did hit 100 in a couple blinks of an eye he said...
blows his Porsche GT away he said...
flat out...
When We Were Hanginout We Talked About His Test Drive Of The 300c Srt8. Man Did He Hate That Car! "typical American Slush Box, Doest Handle Or Turn, Good Only Or Straight Lines, But That All You Yanks Care About" Not Word For Word, But Damn Close
According to the August issue of "Automobile", Bugatti is planning a two seat roadster, 4 cyl turbo with 280-320 hp, seven sp auto. Concept drawings look really siiiiccck :naughty: It'll be a Lotus Elise competitor with price ONLY $60k. Here's a pic:
The above being stated (not actual) WE do have more "straights" then their "bends". So ya "WE" do care about "our lady of horsepower".:) :) :)
1 - 18 of 18 Posts
