1 - 10 of 10 Posts
Just wanted to know what you alls thoughts were on this kit. Seams to be fairly good kit to me. But then again I am not what one would call an expert in the world of air suspension. I found this at
https://kmwperformance.com/
specs are as follows
4 Way Air Management System
Each air spring has a separate air line. This four corner system provides maximum versatility for clowning or weight control. The vehicle can be leveled side-to-side or front-to-rear.
1 - Viair 450C Chrome Compressor
1 - Pressure Switch 110-145PSI
1 - Air Lift 5 Gallon, 8-Port Tank
8 - Air Lift 3/8" Chrome 300PSI Electric Valve
2 - Dual Needle Gauge 200PSI
4 - Rocker Switches
3 - Fuse Holders with Cover
3 - 15 AMP Spade Fuse
6 - 30 AMP Spade Fuse
1 - 40 AMP Heavy Duty Relay
1 - Single Relay Socket
50ft of 1/2" DOT Synflex Air Line
50ft of 1/4" DOT Synflex Air Line
2 - Thread Sealant Packet
1 - Air Line Cutter
1 - 1/2" Street Tee Fitting
2 - 1/2" NPT to 1/4" FEM Bushing Fitting
2 - 1/2" NPT to 1/8" FEM Bushing Fitting
1 - Drain Cock Fitting
1 - Inflation Valve Fitting
1 - 1/2" NPT Hex Plug Fitting
4 - 1/2" NPT to 3/8" FEM Bushing Fitting
4 - 3/8" Street Tee Fitting
8 - 3/8" NPT to 3/8" NPT Straight Fitting
4 - 3/8" NPT to 1/2" Line Elbow Fitting
4 - 1/4" NPT to 1/2" Line to 1/2" Line Tee Fitting
4 - 1/4" FEM to 1/4" Line Straight Fitting
Check out the air kit upgrades section at the left for upgrades and additional items.
Dodge Magnum - Front (2002-2006)
Includes left and right air struts.
Dodge Magnum - Rear (2002-2006)
Manufacturer: KMW Performance
Discussion Starter · #5 ·
2300 was the price check out the web site :wave:
Discussion Starter · #6 ·
stinasaurus said:
are there pictures of the kit?
they don't have pics of the kit alltogether but they do have them of each componet.
my air ride system came out to 3,500.00 installed and it was a higher setup.
I'll tell u this, your going to need a bigger compressor instead of the 450.
You should get the viair 480 and u should get at least 2, if not then 3.. but 1 willl not be good enough. That and at least 2 - 5 gallon tanks.
1 - 10 of 10 Posts
