smoove7410 said:I like the rim/tire size combo, but not the actual style rim. Does anyone know when eibach will have a set of springs out, and also how was 50 cent's 300c dropped?![]()
MOMO said:Yeah, how are people able to put on those massive wheels on? Stick your hand in between the wheel gap and you’ll see what I mean.
Bigger wheels does not mean a taller tire to diminish wheel gap. When you upgrade wheels and tires you use a setup that is close to the same as the OEM tire height. The 300C tire is 28.6" tall using 225/60/18 tires. Doing a plus-1 (19"), plus-2 (20") or plus-4 (22")' you are supposed to maintain the same height of 28.6 or something very close to it.MOMO said:So, no one knows how to get around that big old thingamajig in between the wheel gap? That will obviously be a huge obstacle in regards to put on bigger wheels![]()
Actually I was not referring to the wheel gap itself. I was referring to the suspension part that sticks out like a sore thumb. It protrudes directly form the lower part of suspension and ends just above the wheel itself. I hope that this clears things up.E55 KEV said:Bigger wheels does not mean a taller tire to diminish wheel gap. When you upgrade wheels and tires you use a setup that is close to the same as the OEM tire height. The 300C tire is 28.6" tall using 225/60/18 tires. Doing a plus-1 (19"), plus-2 (20") or plus-4 (22")' you are supposed to maintain the same height of 28.6 or something very close to it.
The only way to get rid of that wheel gap will be shorter springs. We will have to wait for a sport suspension from Mopar and aftermarket lowering kits. They are coming.![]()
E55 KEV said:MOMO, is this the suspension part you are referring to? I have seen that on a 300C. This photo is from my E55, however, that bolt is behind the tire on W210 E-Class cars and for Chrysler 300 LX chassis it is above the wheel. That bolt limits the front tire and wheel upgrades on the W210 E-Class. It causes tire rub when I changed my front wheel offset inward by only 4mm!
I remember seeing a bolt with nut. That was the first thing I checked out (wheel well) on the first 300C I came across. The section causes much problems with wheel/tire upgrades on the W210 Mercedes so I wanted to see how the LX chassis looked compared to the W210. They move the arm above the tire on LX instead of behind the tire on W210. The LX also differs - it uses a coil spring over Damper while the W210 has separate coil and damper.MOMO said:Thanks for the pic. The arrow is pointing to the right area, but it’s not a bolt it’s more like an arm sticking (for lack of a better description) or at least it appears that way on the 300. It’s sticks out a couple of inches directly above the front wheels. Once again thanks for post that pic.
