1 - 20 of 31 Posts
Ok, minor problem here... My order sheet and window sticker/sheet clearly indicate I've got Option Group II (Kicker) on my car (and I paid for it).
Problem is, where is it? Is there anything in the car that says "Kicker"? I assume there should be a big sub in the back somewhere. Don't see anything here:
Maybe it's a "stealth" install :silly:
Anyone know (or have pics) of it in a Magnum? This isn't a huge deal to me, certainly not enough to put off delivery over a long weekend. Perhaps a brampton worker was having a :friday:
Thanks for any input.
BrettG
hmmmm - don't see it where it is supposed to be...
do a search here...
there is a picture of where it is supposed to be somewhere on this site...
contact KCustom via PM - he'll have something...
that is not good...
sorry man...
The sub should be in the back....take a look through the grills and see if you see the kicker speakers if you do the sub is missing if not the car was mis built.....
ask for the man himself and receive
THANKS KCUSTOM!
I cannot wait to get mine with your wonderful system gracing its interior with melodic and harmonious sounds...
ok, it will be pumping at its limits from the get go and I'll be PM'ing you on what I can upgrade to to make it louder...
whose kidding who... :biggrin:
from the pictures on another post it looks like the car has the other Kicker speakers in it (or at least the drivers door) I would get with your dealer and find out what happend to your sub....it will only take a min or two to instll it. Here are some picts.....
I am going to follow this closely. We get our MSRT-8 on Sunday and it lists option group II but it does not have the kicker system in it(from the dealership). I have not seen it in person, yet. Your pictures introduced a little more anxiousness into this very short wait :D
Discussion Starter · #7 ·
Thanks everybody. Here's a few more pics.
From what I can tell there's 6 speakers in my car - 2 dash, 2 front doors, 2 in back cargo area. If there's any area somebody would like a pic of, let me know.
The dash speakers
Didn't see any connector around this area
Better pic of the door
BrettG
the beauty of this site...
has been realilzed by you...
you have a picture of the actual Kicker Sub and its location...
doesn't get much better than in any court of law...
wait...
you dealing with a car dealership...
GOOD LUCK!
I know before everyone hammers me - most are good and some are even great...
KCustom's photo should help you out bigtime...
FYI - Kicker's are made in Oklahoma - :wink1: :wink1:
wait...
GOOD LUCK!
CButler, you and all your cloak and dagger stories crack me up. Some day you will get your car and be happy. Your posts will either go up or down depending on when you actually get your car.............
The plug for the sub should be under the carpet flap that you have up in the picture on the drivers side.....it should be a four pin flat plug....if the unit was stolen the wiresw may have been cut....if someone just forgot to install it at the plant the plug may have been put under the pad....One thing for sure you should have a 10" sub in the back of your car.
JohnnyVIG
Only Up Baby!!!
If only I was able to share everything huh???
· Premium Member
More pics please!!!!
Nice pics Brett!! In the second set of pics u posted, I noticed a panel in the rear of the vehicle on the drivers side. Is the Kicker behind it? Also, from the pics I see you have the bright silver paint. This is the first time I've seen a silver Mag SRT-8 on any of the sites. Can you post some more pics of the beast?
Thanks,
Mungo404
Discussion Starter · #13 ·
Thanks. There's no plug or wire that I can see or feel (without pulling everything out of the rear compartment). If you know, is the wire part of every car, or just put in specifically for the sub?
The subwoofer harness is in all SRT Magnums..it may be under the foam pad on the floor and the plant forgot to install the subwoofer assembly. the sub mounts to the m12 stud on the floor under the carpet flap and sits behind the rear seat on the drivers side. It amazes me that the car could get out of the plant with out the sub...
Discussion Starter · #15 · (Edited)
Thanks,
Mungo404
Hey Mungo, it's Brilliant Black... :silly: I think the pics are probably washed out / highlights blown which is why you thought it was silver.
See http://www.300cforums.com/forums/showthread.php?t=8003
or gallery for more pics.
The panel you mention is just part of the interior plastic trim of the rear compartment. As far as I know, there's nothing behind it but frame and it doesn't open or come off.
[Edit -woops, my galley link was bad...]
Discussion Starter · #16 ·
Thanks, I'll take a better look later (now, where'd I put that sawsall? :saeek: )
Thanks for putting up that pic of the sub - printed and will take to dealership Monday.
· Premium Member
KCustom said:
...It amazes me that the car could get out of the plant with out the sub...
Mistakes like that are a one in a million... the build sheet lists the Kicker system, and as mentioned so does the window sticker. Most likely it was stolen or someone at the dealership "borrowed" it for another vehicle or something...
The tire inflator's there - if you look at his pics on the other thread, in the spare-tire-cubby bin thing, it's on the left hand side. It's packaged upside-down, opposite the battery. It's got a little orange nozzle on it, which would be great for using the tire-fit kit as a beach ball inflator when you take your SRT-8 to the beach!
:silly:
Just make sure you undo the compressor hose from the fill bottle first. I've heard/read horror stories about accidentally turning the thing on w/out it being hooked up to a tire!
1 - 20 of 31 Posts
