shanemcse said:
...I just don't believe having holes and slots is a bad thing. If it was a bad idea then why do so many places offer them?
For example here are some pretty popular sites that offer rotors with holes and slots.
http://www.tirerack.com/brakes/brakes.jsp?make=PowerSlot&model=ProStop+II+Rotor
I am not trying to argue but I just would like some kind of proof seeing how so many places offer them.
Hi shane. I'm here to learn, and very much appreciate you and the information you're sharing. So don't take anything I say here as being argumentative, or worse.
Because it's not.
This forum is "blessed", if I can use that word here, to have one of the brake industry's foremost wizards in close attendance, Dave Zeckhausen of Zeckhausen Racing. He's "in the trenches" with racers from all aspects of motorsport on a regular basis, sees the effects of good & bad design on a near-daily basis, and is bright enough to make pertinent application of this "insider" information.
So if I'm going to be setting up a car for racing, Dave's word is gospel for me - his credibility is sky high. I need no second opinion.
So I suppose the question is, how closely do I need to follow what Dave knows to be best for track applications if I'm only going to run my car on the street? For me, the answer is probably 100%, because of my God-given wild hair that I'll never outgrow...I manage to find sections of road that enable me to put my 300C through its paces in a very demanding manner with some regularity. For others, it may be less crucial.
It's interesting, shane, that your very first reference, the one from Tire Rack, supports Dave's findings by offering a
faux drilled, slotted rotor, since cross-drilled rotors, especially when combined with slotting, tend to crack. The "holes" are merely cosmetic dimples in the rotor's surface. Here's the short version of that product description:
From Tire Rack:
http://www.tirerack.com/brakes/brak...roStop+II+Rotor
"It’s a fact that venting the gas emitted by hot brake pads improves overall brake performance and helps minimize fade. At one time the conventional wisdom in racing circles was to cross-drill brake rotors to aid cooling and eliminate the gas emitted by brake pads. However, today’s elite teams in open wheel, Indy and Trans Am racing are moving away from crack prone, cross-drilled brake rotors in favor of rotors modified with a fatigue resistant slotting process.
Power Slot’s ProStop II rotors were developed to combine the look of a cross-drilled rotor with the durability of a slotted rotor. ProStop II rotors are enhanced with a series of four drilled “dimples” that look like cross-drilled holes (especially when brake dust is collected at the bottom of the dimples after several hundred miles of driving). By installing ProStop II rotors, a driver can have the “look” of a cross-drilled rotor and the performance of a slotted rotor without compromising the structural integrity of the rotor. ProStop II rotors with their faux-drilled dimple treatment are specifically designed to provide a safer alternative to drilling crack prone holes through cast iron rotors and offer a more aggressive appearance than the original ProStop rotors.
Power Slot's slotting process and faux-drilled treatment removes less heat absorbing mass and less of the rotor’s surface area than conventional cross drilling to help maintain the highest possible co-efficient of friction for the brake pads to work against."
If the rotors you've purchased are truly cross-drilled, as well as being slotted, then I suppose the question is "will they hold up just fine under normal street use?". My guess is yes. How would they fare under
very demanding street and back road use? Probably not very well, from what we've read.
So they may be perfectly fine for you, and perhaps many others here as well - they look great, they're treated against rust, and appear, from reading, to have good metal in them.
If
I, however, because of my need for speed, were to quickly grab a set of rotors just from the offerings you've presented I'd choose the Power Slot ProStop II's - for the reasons clearly laid out in the above quote.
Just my thoughts. Please keep on posting.
