Still need help anyone know how to fix this??
Once it's calibrated, let it go back to its resting position. From there, pop off the plastic accordion style covers on the sides. You'll see 4 torx head screws holding the glass in place. AFTER calibrating, adjust the sunroof to fit properly. It's handy to have two people for this as well, one inside the car with a screwdriver and pushing up, and one outside to push the glass back down when you push it too high.SYMPTOM/CONDITION:
Sunroof does not fully close (fit flush to roof) and/or fully vent and/or is noisy at the end of
full open travel.
DIAGNOSIS:
1. Verify the rear of the sunroof glass to roof flushness concern.
2. **UNCALIBRATE THE SUNROOF.
a. Insure the battery is at least 12 Volts.
b. Place the ignition switch in RUN position.
c. Locate the sunroof fuse (Fuse 44 in the Power Distribution Center located in the
trunk).
d. While the sunroof is still in motion, have an assistant remove the sunroof fuse.
e. Reinstall the sunroof fuse.
3. RECALIBRATE THE SUNROOF
a. Press and hold the sunroof vent switch until it stops at the full vent position.
b. Verify sunroof operation by opening, closing, and venting the sunroof.
c. If the uncalibrate/recalibrate procedure corrected the sunroof glass to roof fit,
perform the Repair Procedure.
4. If the uncalibrate/recalibrate procedure did not eliminate the sunroof glass to roof fit,
use the procedures outlined in TechCONNECT® BODY/SUNROOF/GLASS
PANEL/ADJUSTMENTS to adjust the glass panel. If the sunroof glass is now flush,
perform the Repair Procedure.**
I have a 2017 300c So the problem is still existing on into their latest years.Lawsuit related to leaking 300c sunroofs
We are currently investigating claims from owners of 2006-2011 cRYSLER 300C'S that have had sunroof leaking problems that have not been repaired. Many drivers don't know that this problem is well known to Chrysler and its agents, who have refused to address and correct the faulty drainage tubes, claiming that the leaks result from other non-Chrysler factors and not covered under warranty. However, between 1999 and 2010 Chrysler issued no less than NINE Technical Service Bulletins addressing the issue of faulty drainage tubes and water leaks.
The leaks can cause the following physical damages:
• Degradation of structural components, wiring and passenger cabin;
• Shorts in the electrical circuitry;
• Engine stalls;
• Instrument malfunctions in seat and window controls;
• Standing water on floors and mats leading to degradation of floor carpeting and
sub-structure;
• Water stains;
• Hazardous mold and mildew, with associated smells;
• Dampened and damaged interior seats and headrests;
• Weakened components and structures; and
• Rust.
If you have experienced this problem please reply or send me an email at [email protected]. Thanks all and thanks to the webmaster for maintaining such a comprehensive site.
I’m with a 2017 Chrysler 300 C and mine just started with the leaking they replaced my whole sun moon roof track with whole new sun and moon roof re installed.. get it home, days later it starts leaking with another rain..Hey Guys, its been a while since i posted on here, but i recently found out i have a leaking sunroof. It started after a good rain I had about 1in of water in the driver rear floor, not in the front but in the back...cleaned it out and I was thinking A-Pillar...so a while goes by and I went to get my car washed and when the guys was detailing the inside he calls me over and shows me that there is water dripping from the light above the rear door....so im thinking the seam that runs across the roof...well a few days later and another big rain and when i get into my car and back up I hear this rush of water over my head and i look behind me and the water is again dripping from the light above the rear door... so after the rain i look closely at my sunroof..it is level with the rest of the roof, and it looks to be in good cosmetic condition. but i can easily push my car key (it is what was in my hand at the time) between the sunroof and the car it just seamed to be too much space and not making a good seal...and this is all the way around front back and both sides...so my question is can i replace the liner?? or I was thinking of maybe a "Car magnet" to cover it while it rains??? any sugestions???
Mine too!I’m with a 2017 Chrysler 300 C and mine just started with the leaking they replaced my whole sun moon roof track with whole new sun and moon roof re installed.. get it home, days later it starts leaking with another rain..
I have a 2018 with 24,000 same problem, rear passenger sideI have a 2018 and mine is leaking! They have tried to fix my car over and over doesn't even have 36k on it!
I couldn’t get the rubber elbow off at the bottom of the drain tube but I blew it out. Hopefully it will work. Getting a bit of rain tonight so we’ll see what happens. Fingers crossed.Same issues here. 2017 300S with panoramic. I have water leaking from the rear overhead light/handle. I was able to locate the tubes and cleared them out. Still leaking. Looks like the tubes are not draining fast enough and the tray is filling up. I’m looking at clearing out the bottom of where the tubes connect. It looks like a rubber elbow at the bottom where it connects to the rear wheel frame. Still trying to get the rubber piece off the frame. I will let you know if it fixes it.
So it been raining pretty consistently now and the leak on my rear seat overhead handle is no longer there. Looks like it is gone for now. Long story short, if you clean your drain tubes make sure to also clean out the rubber elbow at the bottom of the drain tube where it connects. Hope this helps someone.I couldn’t get the rubber elbow off at the bottom of the drain tube but I blew it out. Hopefully it will work. Getting a bit of rain tonight so we’ll see what happens. Fingers crossed.
