I'm about to change my coolant and I hear I have to drain the coolant from the block as well.
Does anyone know exactly where on the block (or a pic of what the plugs look like)??
no plug on the block. just remove the lower radiator hose. there is however a drain plug on the radiator.
That's what I did.
But from what I hear, there's a plug on each side of the block to drain cooland from there as well.
There is a plug on most engine block to drain the coolant. On the HEMI, it's a bit behind the motor mount and a couple inches above the oil pan. On my 6.4, it was a brass colored bolt. One on each side. Pulling those is the only way to really get everything out.
