I guess it does make sense that failure of a sensor on startup should throw a code but multiple issues being caused by something so simple seems crazy. I guess that's a feature of us driving computers on wheels these days
So far so good, it has been four days and I have used the car each day without the problem reappearing, I was worried I was in for a £1000+ sensor (hope I haven't spoken too soon!).
Going to do another code scan and a battery/alternator test over the weekend. But yes I do hope anyone having a similar problem in future will try cleaning the outside of the sensor housing first!!
Pretty much;
Computer fault finding does it's best to work out what is wrong based on it's preset "list of things it could be."
We had it in it's infancy in 1978 with "fault codes on radar". We never used them; as they were useless, and almost always wrong - THEN.
They are far better now; but to cover EVERY POSSIBLE FAULT/REASON - how big does the list become?
Like when you log on laptop and make password mistake - and it says "system error/can't log you on come back later". It SHOULD say "wrong password." So can be misleading. Some is lazy programming, some is limited memory. But sometimes computer trying to "work it out/draw wrong conclusion from symptoms".
My car did the same when I had the PCV seal fail. It put up a few codes, all related to wrong airflow; but mostly about throttle body and the like. Wanted me to replace throttle body/airflow sensors, etc etc. And it put up two lights (throttle body/ABS) and ABS NOTHING to do with it. It was made more confusing; because it THEN set a very rough idle - to "make sure I'd notice/fix it." Fair enough; (was only unusually long idle period that set it, otherwise wouldn't have noticed) but scared the hell out of me, as seems like major engine management failure.
The "two lights unrelated" thing is probably an "in house dealer code" that the Mopar techs recognise for "manifold leak". But fault code could have just said "manifold leak".
I used a tube in my ear, and could hear it. Fixed seal - perfect.
But brilliant diagnostics on your part. Well done.
