lower control arm bushing
9.8K views 1 reply 2 participants last post by  robaustin
#1 ·
so my mechanic told me that my lower control arm bushings are cracked and that i need to replace the entire control arms. he also says its a common problem on the 300s and chargers. do i have to replace the entire control arms or are there inserts/replacement bushings i can buy? i have a 300 touring and i noticed that pedders has bushings for the lx. can these be used on the touring?
#2 ·
The bushings should be the same and replacing with the Pedders is a good move. If you are unsure, you can check with Pedders.
