Includes all bulletins released through: July 31, 2011
Includes all LX, LD and LE Models: 300 series, 300C, 300N, 300M, Magnum, Charger + all R/T and SRT8's
Section 1: TSB's (Technical Service Bulletins)
Compiled by ResumeSpeed
Newest Releases
TSB Date .. Model Yr … TSB # …............................ Description...................... (Applicable models)
06/24/11 … 2011 .. #21-007-11 …. Flash: Service 4WD Light Illuminated With C1078 Stored .. (3C)
06/24/11 … 0710 .. #18-032-11 …. Flash: MIL Illumination For P2181 - Cooling System Performance .. (3MC)
06/23/11 … 2011 .. #08-034-11 …. Flash: Service Keyless System Displayed In EVIC .. (C)
06/17/11 … 2011 .. #08-032-11 …. Flash: U1411, Instrument Cluster Chime Locks Up .. (3C)
06/16/11 … 0810 .. #18-031-11 …. MIL Illumination for P0128 - Thermostat Rationality .. (3MC)
06/15/11 … 2011 .. #23-022-11 …. Bowing In Front Fascia And/Or Gap Above Headlamp .. (3)
06/14/11 … 0710 .. #08-029-11 …. Radio May Shut Down And Reset Intermittently (export models with REW radios) .. (3)
06/14/11 … 2011 .. #08-016-11a .. Flash: B1606-95, B16AF-15, B16B3-15, B1632-15, B1636-15, Passive Entry Slow Response, Trunk Lamps Shut Off To Quick .. (3)
06/07/11 … 2011 .. #08-028-11 …. Decklid Will Not Open When Pressing The Passive Entry Switch .. (3C)
06/02/11 … 2011 .. #08-026-11 …. Hands Free Phone Volume Does Not Return To Normal After Vehicle Warning Detection .. (C)
05/17/11 … 2011 .. #08-023-11 …. FLASH: Hands Free Module Software Enhancements .. (3C)
05/12/11 … 2011 .. #08-022-11 …. Flash: Ghost Chime From Blind Spot Detection System .. (3C)
04/28/11 … 2011 .. #08-019-11 …. Tail Lamp Bulb Outage May Not Work .. (C)
04/26/11 … 2011 .. #18-018-11 …. Flash: MIL Illumination For Any P06DD, P0522, P0108, P1239, P0298 .. (3C)
04/07/11 … 2011 .. #08-017-11 …. Radio Powers On After Network Goes To Sleep .. (C)
04/07/11 … 2011 .. #08-016-11 …. Flash: B1606-95, B16AF-15, B16B3-15, B1632-15, B1636-15, Passive Entry Slow Response, Trunk Lamps Shut Off To Quick .. (3C)
03/24/11 … 2011 .. #14-003-11 …. Alternative Fuel Label Missing From Windshield .. (3C)
03/18/11 … 2011 .. #08-014-11 …. Driver's & Front Passenger's Window Have Auto Up Down Function But Only Front Passenger Switch Has AUTO Printed On It .. (3C)
Part 1A: Multiple Model Years 2005 - 2010
02/05/11 … 0810 .. #18-005-11 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set .. (3MC)
10/30/10 … 0910 .. #18-029-10 …. Flash: MIL Illumination P0138 And/Or P0158 (3.5L) .. (3C)
10/21/10 … 0710 .. #23-018-10 …. Lower Door Hinges Make Popping or Groan When Opened Or Closed .. (3MC)
07/29/10 … 0910 .. #19-005-10 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers .. (3C)
07/28/10 … 0910 .. #08-020-10 …. Remote Start Intermittently Inoperative .. (3C)
07/23/10 … 0810 .. #18-024-10 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (3.5L) .. (3MC)
07/23/10 … 0810 .. #18-023-10 …. Flash: Rough Idle On Start Up With Ambient Temperatures Below 50° (10° C) (2.7L) .. (3MC)
07/08/10 … 0710 .. #18-015-10b .. Flash: MIL Illumination For P2181 - Cooling System Performance .. (3C)
06/29/10 … 0810 .. #08-014-10 …. REN and REZ Radio Lock Up. Flash Radio with DVD Update Disc .. (3C)
03/02/10 … 0810 .. #08-004-10 …. Radio Video Disable Update .. (3C)
09/01/09 … 0509 .. #14-001-09a .. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly .. (3MC)
07/29/09 … 0510 .. #22-002-09 …. Chrome Clad Wheel Adapters For Proper Balancing .. (3MC)
05/09/09 … 0506 .. #18-015-09 …. Flash: MIL Illumination Due To Diagnostic Trouble Code P0340 Or P0344 .. (3MC)
04/15/09 … 0509 .. #14-001-09 …. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly .. (3MC)
02/27/09 … 0609 .. #09-001-09 …. 3.0L Diesel Alternator Inoperative .. (3)
02/13/09 … 0809 .. #08-003-09 …. MyGig REN or REZ Radio Inoperative After Battery Disconnect .. (3MR)
12/03/08 … 0809 .. #18-036-08a .. Flash: Whistle Sound From Engine Compartment/Purge Solenoid (supersedes 18-036-08) .. (3MR)
11/22/08 … 0809 .. #18-040-08 …. MIL Illumination DTC ode P0339 - Crankshaft Position Sensor Intermittent Set (2.7L) .. (3MR)
09/30/08 … 0609 .. #09-003-08 …. 3.0L Diesel Alternator Inoperative (export models only) .. (3)
09/19/08 … 0708 .. #23-028-08 …. Squeak or Groan Sound When Raising or Lowering Door Glass .. (3MR)
09/17/08 … 0509 .. #21-021-08 …. Automatic Transmission Diagnostic Tear Down Procedure .. (3MR)
09/17/08 … 0708 .. #21-018-08a .. Flash: DTC P0740 or P1798 & Shift Improve 1-2 or 2-3 Shift Improve (supersedes 21-018-08) .. (3MR)
07/12/08 … 0708 .. #21-018-08 …. (superseded by #21-018-08a dated 9/17/07) .. (3MR)
06/24/08 … 0709 .. #05-002-08a .. Pre Delivery Brake Inspection Procedure .. (3MR)
06/05/08 … 0506 .. #22-002-08 …. Flash: Tire Pressure Monitoring System Deactivation (International Markets Only) .. (3MR)
05/15/08 … 0708 .. #24-005-08a .. Flash: A/C ON Does Not Engage Right After Engine Is Started (3.5L export) .. (3MR)
05/14/08 … 0708 .. #05-002-08 …. Pre Delivery Brake Inspection Procedure .. (3MR)
04/08/08 … 0607 .. #18-006-08a .. FLASH: 3.0L Diesel - No Start Cold / Hard Start Warm (supersedes 18-006-08) .. (3)
04/08/08 … 0607 .. #09-001-08 …. 3.0L Diesel Engine Tick, Rattle Or Knock Sound .. (3)
02/19/08 … 0507 .. #23-009-08 …. Rattle Sound in Sunroof Area .. (3MR)
01/19/08 … 0708 .. #18-003-08 …. Flash: MIL Due To DTC P0524 - Engine Oil Press. Low (supersedes 18-044-07) .. (3MR)
01/16/08 … 0508 .. #23-004-08 …. Ratcheting Sound During Sunroof Operation (supersedes 23-045-06) .. (3MR)
01/10/08 … 0708 .. #18-001-08 …. Flash: Momentary Fluctuation Of The Speedometer Needle (2.7L) .. (3MR)
12/19/07 … 0507 .. #03-004-07 …. Ringing Sound From Propeller Shaft When Trans Shifted D to R or R to D .. (3MR)
12/18/07 … 0608 .. #24-008-07 …. A/C Cut Out At High Speeds Of 180 kph (111 mph) (3.0L export models) .. (3)
12/05/07 … 0508 .. #08-029-07 …. Color And/Or Brightness Difference On HID Replacement Headlamp Bulbs .. (3MR)
11/13/07 … 0507 .. #19-005-07 …. Steering Column Dash Seal Squeak/Rubbing Sound .. (3MR)
10/30/07 … 0608 .. #23-046-07 …. Paint Repair - Etching .. (3MR)
10/16/07 … 0508 .. #21-014-07 …. Automatic Trans Fluid Usage ATF+4 (Type MS9602) .. (3MR)
10/10/07 … 0708 .. #08-024-07 …. Distorted Sound In Speakers (base systems only) .. (3MR)
10/03/07 … 0508 .. #02-004-07 …. Right/Left Lead Revised Alignment Specifications (supersedes 02-005-05) .. (3MR)
10/02/07 … 0608 .. #09-005-07 …. 3.0L Diesel Oil Filter Cap Service (3.0 diesel models) .. (3)
09/25/07 … 0608 .. #09-004-07 …. Engine Cranks But Will Not Start (3.0 diesel models) .. (3)
08/31/07 … 0508 .. #22-003-07 …. Wheel Lug Nuts .. (3MR)
08/08/07 … 0508 .. #23-035-07 …. Exterior Lamp - Lens Fogging .. (3MR)
06/06/07 … 0607 .. #08-015-07 …. Flash: Sunroof Module, Excessive IOD, Pop In Radio, Dome Lamp Flickers .. (3MR)
05/16/07 … 0507 .. #08-001-07b .. Passenger Air Bag Deactivation (supersedes 08-001-07b) .. (3MR)
04/27/07... 0607 .. #18-026-07a .. Flash: ND 4.7L - Downstream Oxygen Sensor - Slow Response &/or Fuel Trim DTC's .. (3MR)
04/17/07 … 0607 .. #18-027-07 …. Flash: MIL Illum. EGR Position Sensor DTC P0404, P0405, or P0406 .. (3MR)
04/13/07 … 0607 .. #05-001-07 …. Police Brake Front Pad Lining Life and Noise .. (MR)
03/30/07 … 0507 .. #26-003-07 …. Fluid Flushing Requirements .. (3MR)
02/09/07 … 0507 .. #21-003-07 …. Auto Trans Diagnostic Tear Down Procedure .. (3MR)
02/07/07 … 0607 .. #11-001-07 …. Turbocharger, Chg. Cooler & EGR Sy. Diag. on OM642 Eng. (export) .. (3MR)
02/07/07 … 0507 .. #08-001-07a .. Passenger Air Bag Deactivation (supersedes 08-001-07) .. (3MR)
02/02/07 … 0607 .. #23-005-07 …. "A" Pillar Water Leak .. (3MR)
01/03/07 … 0506 .. #08-001-07 …. Passenger Air Bag Deactivation (supersedes 08-032-05) .. (3MR)
12/20/06 … 0506 .. #21-020-06 …. Delayed Or Rough 1-2 shift at WOT After Kickdown (6.1L only) .. (SRT)
12/19/06 … 0607 .. #18-012-06a .. MAP Sensor, DTC's P0652/P0340/C121C/P2127 (supersedes 18-012-06) .. (3MR)
12/09/06 … 0506 .. #09-011-06 …. Engine Whine Sound at Idle (6.1L only) .. (SRT)
12/05/06 … 0607 .. #08-049-06 …. Instrument Cluster Resets If Driver Exits Vehicle… .. (3MR)
11/17/06 … 0506 .. #18-035-06 …. FLASH: Malfunction Indicator Lamp (MIL) On For P0573 .. (3MR)
10/28/06 … 0506 .. #18-031-06 …. Flash: Delayed Engine Crank or MIL DTC P0573 (2.7L/3.5L) .. (3MR)
10/21/06 … 0607 .. #23-047-06 …. Cracked Windshield .. (3MR)
10/14/06 … 0507 .. #23-045-06 …. Ratcheting Sound During Sunroof Operation .. (3MR)
10/04/06 … 0607 .. #22-004-06 …. Tire Pressure Monitor - System Information (supersedes 22-002-05) .. (3MR)
10/03/06 … 0506 .. #21-012-06b .. Flash: 1-2 Upshift Shudder or Rough Shift (2.7L and 3.7L only) .. (3MR)
09/27/06 … 0607 .. #23-041-06 …. Exterior Lamp - Lens Fogging .. (3MR)
09/26/06 … 0506 .. #23-040-06 …. FLASH: Rear Of Sunroof Glass Not Flush To Roof/Sunroof Will Not Close .. (3MR)
09/16/06 … 0506 .. #09-010-06 …. Multiple Cylinder Misfire Or Rough Idle (3.7L, supersedes 09-005-05) .. (3MR)
09/09/06 … 0607 .. #26-007-06 …. Owner Manual Addendum - Maint. Sched. Diesel Eng.- Export Only .. (3MR)
09/09/06 … 0607 .. #26-008-06 …. Owner Manual Addendum - Fluids & Capacities - Export Only .. (3MR)
08/02/06 … 0507 .. #24-006-06 …. A/C Cooling Coil Odor (supersedes 24-013-05) .. (3MR)
08/02/06 … 0506 .. #05-006-06 …. Front And/Or Rear Brake Rotors Grooved/Scored .. (SRT)
07/27/06 … 0506 .. #23-031-06 …. Windshield Header Buzz Or Humming Sound .. (3MR)
06/15/06 … 0506 .. #21-012-06a .. Flash: 1-2 Upshift Shudder/Rough Shift 2.7/3.5 (supersedes 21-012-06) .. (3MR)
05/27/06 … 0507 .. #08-025-06 …. Poor Radio Reception (supersedes 08-32-04) .. (3MR)
05/24/06 … 0506 .. #08-024-06 …. Flash: Memory Seat/Memory Steering Column (supersedes 08-027-05) .. (3)
05/13/06 … 0506 .. #18-018-06 ... FLASH: MIL Illumination DTC P2112 Or P1521 (supersedes 18-035-05a) .. (3MR)
05/10/06 … 0506 .. #23-019-06 …. Adhesive Residue From Protective Covering On Carpeting .. (3MR)
04/26/06 … 0506 .. #08-017-06 …. StarSCAN® Vehicle Scan Report Availability .. (3MR)
04/26/06 … 0506 .. #11-002-06 …. MIL lamp Illuminated and/or Exhaust Rattle (export models) .. (3)
04/19/06 … 0506 .. #21-011-06 …. Transfer Case Shudder (AWD models) .. (3M)
04/14/06 … 0506 .. #21-010-06 …. Auto Trans Fluid Usage ATF+4 (Type MS9602) .. (3MR)
04/01/06 … 0506 .. #08-015-06 …. FLASH: Illuminated Approach, Fog Lamps and/or Rear Wiper Operation .. (3MR)
03/16/06 … 0506 .. #08-014-06a .. Flash: UConnect Fails To Respond (supersedes 08-049-05) .. (3MR)
03/08/06 … 0506 .. #23-014-06 …. Windshield Wiper Blade/Element Maintenance .. (3MR)
02/18/06 … 0506 .. #21-003-06 …. Dipstick Seal May Leak Causing ATF Contam. Or Trans. Shudder .. (3MR)
02/16/06 … 0506 .. #19-002-06 …. Moan/Groan Sound Heard At Idle (3.5L models) .. (3MR)
01/18/06 … 0506 .. #23-002-06 …. Sunroof Rattle Sound .. (3MR)
01/12/06 … 0506 .. #23-001-06 …. Sill Cladding Replacement .. (3M)
12/02/05 … 0506 .. #08-032-05a .. Passenger Air Bag Deactivation Procedure .. (3MR)
12/02/05 … 0506 .. #09-005-05 …. Multiple Cylinder Misfire Or Rough Idle (3.5L) .. (3MR)
11/18/05 … 0506 .. #18-035-05a .. DTC P2112 Or P1521 (superseded by 18-018-06 dated 5/13/06) .. (3MR)
11/12/05 … 0506 .. #21-019-05a .. Transfer Case Shudder (supersedes 21-019-05) .. (3M)
11/04/05 … 0506 .. #23-052-05 …. Rear Fascia To Body Side/Tail Lamp Fit .. (3R)
10/26/05 … 0506 .. #19-008-05 …. Revised Power Steering System Bleeding Procedures .. (3MR)
10/08/05 … 0506 .. #21-019-05 …. (superseded by #21-01905a dated 11/12/05) .. (3M)
10/04/05 … 0506 .. #05-005-05 …. Front And/Or Rear Brakes Squeal When Braking .. (SRT)
10/04/05 … 0506 .. #21-018-05 …. Auto Trans Diagnostic Teardown Procedure .. (3MR)
10/01/05 … 0506 .. #08-013-05a .. UConnect Phone Inoperative (supersedes 08-013-05) .. (3MR)
09/21/05 … 0506 .. #23-043-05 …. Headliner Fit At Backlight .. (3R)
09/09/05 … 0506 .. #23-042-05 …. Liftgate Spoiler Outer Seal Delamination .. (M)
09/09/05 … 0506 .. #23-041-05 …. Deck Lid Spoiler Fit .. (SRT)
09/01/05 … 0506 .. #08-049-05 …. Flash: Uconnect Module No Response Due To Module "Lock Up" .. (3MR)
08/30/05 … 0506 .. #23-040-05 …. Gap Between Carpet & Scuff Plate (supersedes #23-021-04) .. (3MR)
08/23/05 … 0506 .. #21-014-05 …. FLASH: Click Sound From Rear of Veh. After Accel. From Stop .. (3M)
08/04/05 … 0506 .. #24-013-05 …. A/C Cooling Coil Odor .. (3M)
07/26/05 … 0506 .. #23-035-05 …. Circular/Ring Marks On Glass .. (3MR)
07/21/05 … 0506 .. #18-031-05 …. Flash: Shift Hesitation During Wide Open Throttle 6.1L .. (SRT)
07/14/05 … 0506 .. #21-011-05a .. NAG1 (W5A580) Trans Shudder Trq Cnv Clutch Engages .. (3MR)
06/30/05 … 0506 .. #08-034-05 …. MIL Illum. O2 sensor P0037, 0058, 131-133, 138, 151, 153 .. (3MR)
06/03/05 … 0506 .. #19-004-05 …. Steering Column Power Tilt Inoperable.. (3)
05/25/05 … 0506 .. #08-027-05 …. Memory Seat/Memory Steering Column[/font][/color][/font][/color].. (3)
05/04/05 … 0506 .. #08-024-05 …. Radio Communication Equipment Install Recommendations .. (3MR)
04/02/05 … 0506 .. #23-022-05 …. Low Gloss Interior Trim maintenance .. (3MR)
04/02/05 … 0506 .. #24-007-05 …. Knock Sound Heard At Idle With A/C On (A/C clutch/pulley) .. (3MR)
03/12/05 … 0506 .. #02-002-05 …. Right Lead/Revised Alignment Specifications .. (3M)+(SRT)
02/16/05 … 0506 .. #08-013-05 …. (superseded by #0801305a dated 10/01/05) .. (3MR)
02/02/05 … 0506 .. #23-006-05 …. Ash Tray Will Not Open, Will Not Stay Closed etc. .. (3M)
Part 1B: 2011 models ONLY:
02/16/11 … 2011 .. #07-001-11 …. Coolant Weepage At The Coolant Reservoir Hose (3.6L) .. (3)
01/25/11 … 2011 .. #08-004-11 …. Powernet Architecture - Ship to Customer Mode And Tool Cable Requirements .. (3)
Part 1C: 2010 models ONLY:
01/15/11 … 2010 .. #08-001-11 …. RER, REW, REP Radio Software Enhancements .. (3C)
10/28/10 … 2010 .. #08-028-10 …. RBZ Radio Software Enhancements .. (3C)
08/13/10 … 2010 .. #22-003-10 …. Slight Vibration at Highway Speeds (18" wheels) .. (3C)
05/19/10 … 2010 .. #18-008-10a .. Flash: MIL Illumination Or Failed/Rejected At State I/M Test Station Per Symptom/Conditions .. (3C)
03/27/10 … 2010 .. #18-008-10 …. Flash: MIL Illumination Or Failed/Rejected At State I/M Test
02/11/10 … 2009 .. #19-003-10a .. Power Steering Honk, Hiss and or Buzz Sound (5.7L) .. (3C)
01/12/10 … 2010 .. #24-001-10 …. Rear Defroster Switch Engagement Effort .. (3C)
Part 1D: 2009 models ONLY:
05/14/10 … 2009 .. #08-010-10 …. Flash: WIN Module For Intermittent RKE Functions .. (3C)
04/28/10 … 2009 .. #18-014-10 …. Flash: Engine Runs Rough At Low RPM or MIL Illum. For MDS Reactivation and Misfire DTC's (5.7L) .. (3C)
02/09/10 … 2009 .. #23-002-10 …. Loose Heritage Badge On Seat Back .. (3)
12/08/09 … 2009 .. #18-021-09a .. Flash: MIL Illumination And/Or MDS Driveability Improvements And/Or Shift Improvements (supersedes 18-021-09) .. (3C)
10/15/09 … 2009 .. #18-030-09 …. Flash: Driveability Improvements .. (SRT)
08/01/09 … 2009 .. #19-004-09 …. Steering Wheel Returnability .. (3C)
07/11/09 … 2009 .. #18-021-09 …. Flash: MIL Illumination And/Or MDS Driveability Improvements And/Or Shift Improvements .. (3C)
07/10/09 … 2009 .. #19-003-09 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers .. (3C)
05/28/09 … 2009 .. #21-005-09 …. Flash: Harsh 4-3 Shift And Shift Quality Improvements .. (3C)
11/04/08 … 2009 .. #05-005-08 …. Flash: ESP Lamp Flashing While System is in Full Off Mode Or ESP Pump Howl, Groan Sound After A Turn .. (3MR)
10/21/08 … 2009 .. #08-031-08 …. Flash: Trip B Functionality Does Not Reset Using The Odometer Knob .. (3MR)
10/08/08 … 2009 .. #21-022-08 …. Torque Convertor Shudder On Vehicles With Less Then 4000 Miles .. (3MR)
09/18/08 … 2009 .. #18-036-08 …. Flash: Whistle Sound From Engine Compartment/Purge Solenoid .. (3MR)
Part 1E: 2008 models ONLY:
03/19/09 … 2008 .. #08-006-09 …. Flash: RES Radio Clock Lockup and SDARS Reset .. (3MC)
02/23/09 … 2008 .. #08-004-09 …. No Cruise Control Or EVIC Displays "ACC Blinded" Or Re enable ACC Cruise That Has Been Disabled .. (3MR)
12/03/08 … 2008 .. #18-031-08a .. Flash: MIL Illumination Diagnostic Trouble Code P050D - Cold Start Rough Idle Set (supersedes 18-031-08) .. (3MR)
11/27/08 … 2008 .. #08-036-08 …. Flash: Audio System Mutes On Start-Up, Amp Settings After Exiting Hands Free Mode, Nav Vol Corrections .. (3MR)
10/17/08 … 2008 .. #08-030-08 …. Flash: Incorrect Translation For "Oil Change Required" On EVIC Display In French Or Spanish Settings .. (3MR)
10/17/08 … 2008 .. #08-029-08 …. Flash: Incorrect Translation For "Average Fuel Economy" On EVIC Display On UK Country Code Settings .. (3)
10/14/08 … 2008 .. #08-024-08a .. MYGIG Radio Hard Drive Recovery/Update Disc (supersedes 08-024-08) .. (3MR)
09/17/08 … 2008 .. #08-028-08 …. Voice Recognition Screen Lock-up on REN or REZ Radio equipped w/Uconnect .. (3MR)
08/29/08 … 2008 .. #08-027-08 …. UConnect and Voice Recognition Inoperative .. (3MR)
08/15/08 … 2008 .. #08-024-08 …. MYGIG Radio Hard Drive Recovery/Update Disc .. (3MR)
08/14/08 … 2008 .. #18-032-08 …. Flash: Long Crank Times (5.7L) .. (3MR)
05/06/08 … 2008 .. #08-019-08 …. Flash: Radio - CD Loses Last Played Track After A Ignition Switch Cycle .. (3MR)
04/29/08 … 2008 .. #08-017-08 …. Flash: Can Not Adjust Volume At the Navigation Prompt .. (3MR)
03/15/08 … 2008 .. #08-010-08 …. Sirius Backseat TV Diagnostic Procedures .. (3MR)
03/06/08 … 2008 .. #08-008-08 …. Flash: Radio - Sound Mutes Intermittently When Radio Is In SAT (Sirius) Mode .. (3MR)
02/16/08 … 2008 .. #26-002-08 …. Add Parking Brake Adjustment To The 30 Month, 30K Miles Or 50K Km Service Interval .. (3MR)
02/12/08 … 2008 .. #08-005-08 …. No Cruise Control Functions Or EVIC Displays "ACC Blinded" .. (3MR)
02/01/08 … 2008 .. #08-003-08 …. Hard Start/No Start Due to Weak Battery (MyGIG radio) .. (3MR)
12/21/07 … 2008 .. #08-032-07 …. Flash: Radio - Temperature Display In Cluster Revert To U.S. Units Intermittently .. (3MR)
12/21/07 … 2008 .. #08-031-07 …. Flash: Amplifier For Audio System Mutes After Rapid Radio Mode Changes .. (3MR)
12/07/07 … 2008 .. #08-025-07a .. DVD Software Update MYGIG Radio For Many Radio Improvements .. (3MR)
11/16/07 … 2008 .. #18-048-07 …. Flash: MIL Due To DTC P050D, Cold Start Rough Idle (2.7L only) .. (3MR)
10/27/07 … 2008 .. #08-027-07 …. Flash: VES (Over Head Video Screen) Is Not Powering ON .. (3MR)
10/23/07 … 2008 .. #09-006-07 …. Oil Filter Change For Some 2008 Vehicles .. (3MR)
10/12/07 … 2008 .. #18-044-07 …. Flash: MIL Illumination Due To DTC P0524, Engine Oil Pressure Too Low (5.7L) .. (3MR)
09/18/07 … 2008 .. #26-004-07 …. Owner Manual Addendum - Important Notice - Export Models Only .. (3MR)
07/11/07 … 2008 .. #08-014-07 …. EVIC Oil Change Indicator System Service .. (3MR)
Part 1F: 2007 models ONLY:
07/18/08 … 2007 .. #08-022-08 …. Incorrect German Translation For "Fuel Saver" On EVIC Display (export models) .. (3MR)
04/24/08 … 2007 .. #24-005-08 …. Flash: A/C ON Does Not Engage Right After The Engine Is Started (3.5L export) .. (3)
01/05/08 … 2007 .. #21-002-08 …. Flash: Torque Converter Shudder w/Coord. Change Or 1-2 Or 2-3 Shift Harshness .. (3MR)
12/21/07 … 2007 .. #21-002-07e .. Flash: Torque Converter Shudder (supersedes 21-002-07d) .. (3MR)
12/14/07 … 2007 .. #08-008-07a .. Flash: WCM For "Service Tire Pressure Monitor System" displayed in EVIC .. (3MR)
11/08/07 … 2007 .. #21-002-07d .. Flash: Torque Converter Shudder (supersedes 21-002-07c) .. (3MR)
10/20/07 … 2007 .. #21-002-07c .. Flash: **Torque Converter Shudder** (supersedes 21-002-07b) .. (3MR)
07/17/07 … 2007 .. #21-002-07b .. Flash: Torque Converter Shudder / Shift Quality Improvements / DTC P0732 .. (3MR)
07/17/07 … 2007 .. #21-012-07 …. Flash: MIL Illumination With DTC P0741- Torque Converter Clutch Circuit .. (3MR)
06/26/07 … 2007 .. #08-011-07a .. Inoperative Power Window Express Up Feature .. (3MR)
06/09/07 … 2007 .. #18-038-07 …. Flash: 6.1L - SRT8 - Charging System Voltage .. (SRT)
03/08/07 … 2007 .. #08-008-07 …. Flash: Wireless Control Module (WCM) .. (3MR)
03/07/07 … 2007 .. #18-003-07a .. Flash: MIL Illumination DTC P1004 - Short Runner Valve Performance .. (3MR)
02/16/07 … 2007 .. #18-011-07 …. Flash: DTCP0420/P0430 Catalyst Efficiency Rationality .. (3MR)
02/16/07 … 2007 .. #18-012-07 …. Flash: MIL Illumination DTC P013A/P013C O2 Sensor Slow To Respond .. (3MR)
01/31/07 … 2007 .. #21-002-07 …. Flash: Torque Converter Shudder / Shift Quality Improvements .. (3MR)
01/26/07 … 2007 .. #23-004-07 …. Transit Film Removal .. (3MR)
09/21/06 … 2007 .. #08-042-06 …. Oil Press Indicator Illum. - Harness Contacts Compressor Pulley (3.5L) .. (3MR)
Part 1G: 2006 models ONLY:
03/15/08 … 2006 .. #18-008-08a .. Flash: DTC P1521 - Incorrect Engine Oil Type Set (supersedes 18-008-08) .. (3MR)
02/21/08 … 2006 .. #18-008-08 …. Flash: False MIL Due To DTC P1521 - Incorrect Engine Oil Type .. (3MR)
09/13/07 … 2006 .. #09-002-07 …. Swirl Chamber Link Clip May Bind Causing DTC P1270 (export models) .. (3MR)
01/12/07 … 2006 .. #23-002-07 …. Front Door Glass Pops Out Of Run Channel .. (3MR)
10/13/06 … 2006 .. #21-019-06 …. Idle RPM Flare Cold Vehicle - Trans Oil Fill revision (export models) .. (3)
09/01/06 … 2006 .. #23-037-06 …. Deck Lid Rubbing The Paint Off Of The Rear Fascia .. (R)
05/04/06 … 2006 .. #18-016-06 …. Flash: MIL Illumination - DTC P0300 - Multiple Cylinder Misfire .. (3MR)
05/02/06 … 2006 .. #08-018-06 …. No Radio Audio Or Display Following Engine Crank .. (3MR)
04/27/06 … 2006 .. #09-005-06 …. Swirl Chamber Linkage Clip May Bind, DTC P1270 (export models) .. (3MR)
04/20/06 … 2006 .. #21-012-06 …. Flash: 1-2 Upshift Shudder/Rough Shift (2.7L with 42RLE trans) .. (3MR)
03/23/06 … 2006 .. #18-011-06 …. Rough Idle, MIL Illumination, DTC P0303 (2.7L) .. (3MR)
02/08/06 … 2006 .. #08-006-06 …. Police Vehicle Upfit/Modification Information .. (MR)
01/27/06 … 2006 .. #08-004-06 …. Passenger Airbag Disabled Lamp .. (3MR)
01/26/06 … 2006 .. #23-005-06 …. Sill Cladding Rattle Sound .. (3MR)
01/21/06 … 2006 .. #14-001-06 …. Loose Fuel Cap Message or MIL for Trouble Code P0457 .. (3MR)
01/18/06 … 2006 .. #23-003-06 …. Paint Repair - Insect Etching .. (3M)
12/07/05 … 2006 .. #22-002-05 …. Tire Pressure Monitor - System Information .. (3MR)
12/02/05 … 2006 .. #08-061-05 …. Flash: No Start Due To Lost WCM Comm. (international only) .. (3MR)
11/19/05 … 2006 .. #24-014-05a .. Hot Air A/C at Start-up & A/C Sys No Cool After Ext. Driving .. (3MR)
11/19/05 … 2006 .. #24-012-05a .. A/C System No Cool Extended Driving Hot & Humid Conditions .. (3MR)
10/21/05 … 2006 .. #08-056-05 …. Flash: Speaker Cutout At High Volume Or Bass Setting .. (R)
09/21/05 … 2006 .. #23-044-05 …. Trunk Carpet Fit .. (3)
09/29/05 … 2006 .. #18-035-05 …. FLASH: MIL Illumination At Start-Up (DTC P2112 or P1521, superseded by 18-018-06 dated 5/13/06) .. (3MR)
07/27/05 … 2006 .. #08-038-05 …. Flash: Auto Headlamps Sensitivity Improvement .. (3MR)
07/27/05 … 2006 .. #24-012-05 …. Flash: A/C System No Cool After Extended Driving (superseded by #24-012-05a) .. (3MR)
07/23/05 … 2006 .. #21-012-05 …. New 42RLE VLP Trans info (VLP) .. (3MR)
04/27/05 … 2006 .. #08-022-05 …. Flash: EVIC Displays extra Characters .. (3M)+(SRT)
Part 1H: 2005 models ONLY:
10/19/05 … 2005 .. #08-055-05 …. Satellite Radio Intermittent Static .. (3M)
08/27/05 … 2005 .. #23-028-05a … Rear Of Sunroof Glass Not Flush .. (supersedes #23-028-05) (3M)
08/19/05 … 2005 .. #23-038-05 …. Sunroof Squeaks While Opening Or Closing .. (3M)
06/30/05 … 2005 .. #18-029-05 …. Co-Pilot Support and Correct Cable Usage .. (3M)
05/27/05 … 2005 .. #18-026-05 …. FLASH: Rough Idle, Idle Sag, Cruise Control Fails To Engage.. (SRT)
05/07/05 … 2005 .. #21-002-05a .. Automatic Transmission Fluid (ATF) Weepage (O-Ring) .. (3M)
05/05/05 … 2005 .. #23-028-05 …. Rear Of Sunroof Glass Is Not Flush To Roof .. (3M)
03/23/05 … 2005 .. #08-020-05 …. Customer Would Prefer Louder Tone From Park Assist System .. (3)
03/22/05 … 2005 .. #19-002-05 …. Variable Steering Effort In Cold Temperatures .. (3M)
03/22/05 … 2005 .. #21-009-05 …. DTC's P0750, P0755, P0760, P0765, P0846, P0871 or P0841 .. (3M)
03/18/05 … 2005 .. #08-018-05 …. Compass Display Does Not Update .. (3M)
03/16/05 … 2005 .. #08-017-05 …. Headlamps Remain On After Delay Time Out .. (3M)
03/12/05 … 2005 .. #23-007-05a .. Rear Shelf Speaker Buzz/Rattle Sound .. (3)
03/10/05 … 2005 .. #23-018-05 …. Pop/Snap Sound On Right Side Of Instrument Panel .. (3M)
03/02/05 … 2005 .. #08-015-05 …. Powertrain Control Module Initialization .. (3M)
02/25/05 … 2005 .. #23-011-05 …. Rear Grab-Handle Bezel Broken At Screw Boss .. (3M)
02/25/05 … 2005 .. #23-012-05 …. Rattle Sound From Headliner, Rear Shelf Or C- Pillar .. (3)
02/22/05 … 2005 .. #18-011-05 …. Flash - Engine Roughness or Idle Fluctuation .. (3M)
02/17/05 … 2005 .. #08-014-05 …. Mopar Acces Rem Starter Inoperative Due To Hood Switch .. (3M)
02/11/05 … 2005 .. #24-004-05 …. Flash: Poor/Intermitt. A/C Performance (supersedes 24-005-04) .. (3M)
01/14/05 … 2005 .. #21-002-05 …. Auto Transmission Fluid (ATF) Weepage .. (3M)
01/12/05 … 2005 .. #18-003-05 …. Flash: Headlights Fluctuation and/or Int. Lamps Fluctuation .. (3M)
12/08/04 … 2005 .. #18-044-04 …. Cold Start Idle Cycling Or Radiator Steaming At Idle .. (3M)
11/29/04 … 2005 .. #19-010-04 …. Power Steering Fluid Contamination .. (3M)
11/22/04 … 2005 .. #25-001-04 …. Evaporative Systems Service procedures .. (3MR)
11/18/04 … 2005 .. #23-048-04 …. A-Pillar Molding Fit/Wind Noise .. (3M)
11/12/04 … 2005 .. #18-031-04a .. Flash, PCM: DTC P0116, P0139, P0159, P0197, U110B, U1402 .. (3M)
11/04/04 … 2005 .. #09-015-04 …. Engine Oil Viscosity Grades for 5.7L MDS engines .. (3M)
10/22/04 … 2005 .. #23-044-04 …. Puncture In Carpet At Drivers Footrest .. (3M)
10/20/04 … 2005 .. #08-034-04 …. Flash: Theft Security Sys - No Horn During Alarm (export Models) .. (3)
10/15/04 … 2005 .. #08-033-04 …. Left Fr Door Speaker Cut Out At Hwy Speed (export Mag & 300 Tour.)
10/06/04 … 2005 .. #21-006-04a .. Shudder During Shifts .. (3M)
09/30/04 … 2005 .. #08-031-04a .. Cluster Language (Non-Eng.) and/or Metric Selection Not Saved .. (3M)
09/23/04 … 2005 .. #23-038-04 …. Rear Door Glass Binds .. (3M)
09/22/04 … 2005 .. #08-032-04 …. Poor Radio Reception .. (3M)
09/13/04 … 2005 .. #18-009-04a .. Generic Powertrain Control Module (PCM) Procedure .. (3M)
08/06/04 … 2005 .. #09-013-04 …. Gasoline Engine Oil Quality And Viscosity Grades .. (3M)
08/05/04 … 2005 .. #23-031-04 …. A-Pillar Interior Trim Molding Color .. (3M)
07/30/04 … 2005 .. #08-027-04 …. Safety Systems - Vehicle Modifications/Repair .. (3M)
07/27/04 … 2005 .. #08-026-04 …. Amb. Temp Display Slow to Update/Cluster Language Correction .. (3M)
07/08/04 … 2005 .. #21-009-04 …. Flash: TCM Initialize EGS-52 Procedure .. (3M)
06/29/04 … 2005 .. #23-024-04 …. Lift Strap On The Cargo Tri-Fold Load Floor Detaches .. (M)
06/21/04 … 2005 .. #18-027-04 …. Flash: Rough idle or High RPM on Start or Spark .. (3M)
06/15/04 … 2005 .. #02-004-04 …. Suspension/Towing/Lifting Damage .. (3M)
06/15/04 … 2005 .. #23-023-04 …. Windshield Header Buzz Or Humming Sound .. (3M)
06/08/04 … 2005 .. #23-021-04 …. Gap Between Carpet And Front Door Scuff Plate .. (3M)
06/01/04 … 2005 .. #23-020-04 …. Hood Secondary Catch Binding .. (3M)
05/25/04 … 2005 .. #08-021-04 …. Erroneous Radio Diagnostic Trouble Code B221E .. (3M)
05/18/04 … 2005 .. #08-019-04 …. Light Rain Sensor Module Calibration Update .. (3)
05/18/04 … 2005 .. #23-018-04 …. Left Front Door Glass Run Distortion .. (3M)
05/04/04 … 2005 .. #08-018-04 …. Wiper Linkage Contacts MAP Sensor Wiring .. (3M)
04/27/04 … 2005 .. #08-016-04 …. Premium Audio System Intermittent Output .. (3M)
04/27/04 … 2005 .. #23-012-04 …. Real Wood Trim Scratch Repair .. (3M)
04/06/04 … 2005 .. #08-013-04a .. Recal. Procedures Req'd After Batt Disconnect (ESP/Windows) .. (3M)
03/25/04 … 2005 .. #02-003-04 …. Right Lead (superseded by 02-002-05 dated 3/12/05) .. (3M)
03/23/04 … 2005 .. #08-012-04 …. Loss of DTC's Set In Mtple Modules During New Veh. Prep. .. (3M)
03/16/04 … 2005 .. #21-004-04 …. Auto Trans Fluid Usage ATF+4 (Type 9602) .. (3M)
01/06/04 … 2005 .. #08-001-04 …. Front Passenger Airbag Safety Precautions .. (3NM)
09/26/03 … 2005 .. #22-004-03 …. Chrome Wheel Care .. (3M)
--Compiled and maintained by ResumeSpeed 2005-2011
** CONTINUED BELOW **
Discussion Starter #2
Section 2: Recalls, Customer Satisfaction Notices and Rapid Response Transmittals
Part 2A: RECALLS
RCL Date .. Model Yr … RCL # …............................ Description...................... (Applicable models)
11/00/09 … 0910 … RC-J27 … Front Wheel Hub Nuts … (3R)
10/00/09 … 0809 … RC-J26 … Side Airbag Wiring (LE export models) … (3)
08/00/09 … 0809 … RC-J19 … California Emissions Warranty Addendum … (3R)
02/00/09 … 2009 … RC-H41 … Tire Pressure Monitor Sensors … (3R)
11/00/08 … 0609 … RC-H37 … Gearshift Cable (police vehicles only) … (MR)
07/00/08 … 2008 … RC-H23 … Rear Axle Hub Nuts … (3MR)
03/00/07 … 2006 … RC-F47 … Catalytic Converter & Reprog. PCM (replaces TSB 11-002-06A) … (3MR)
02/00/07 … 2007 … RC-F50 … Reprogram ABS Control Module … (3MR)
10/00/06 … 2007 … RC-F43 … Reprogram PCM – Trans Shift Logic (42RLE) … (3MR)
08/00/06 … 0506 … RC-F33 … Directional Signal Bulb Function (export models only) … (3MR)
06/20/06 … 2006 … RC-F18 … Rear Brake Tubes (2.7L only) … (3MR)
11/22/05 … 0506 … RC-E14 … Trans Cup Plug Bracket … (3MR)
09/04/04 … 2005 … RC-D38 … Emissions Recall - VECI Label Replacement … (3M)
07/02/04 … 2005 … RC-D21 … Safety Recall - Rear Floorpan Reinforcement Spot Welds … (3M)
07/02/04 … 2005 … RC-D28 … Safety Recall - Battery Cable Bulkhead Stud Fasteners … (3M)
07/02/04 … 2005 … RC-D30 … Safety Recall - Shoulder Belt Adjuster Turning Loop Bolts … (3M)
05/01/04 … 2005 … RC-D25 … Emissions Recall - Replace PCM and Install Correct Software … (3)
Part 2B: CUSTOMER SATISFACTION NOTICES (CSN's)
CSS Date .. Model Yr … CSS # …............................ Description...................... (Applicable models)
06/00/11 … 0608 … CSN-L08 .. Engine Cooling Fans … (3MC)
04/00/11 … 2011 … CSN-L10 .. Coolant Reservoir Outlet Hose … (3R)
02/00/11 … 0507 … CSN-K39 .. Transmission Shifter Interlock Lever … (3MR)
11/00/09 … 2009 … CSN-J21 … Hot Start Engine Cranking … (3R)
12/18/08 … 2008 … CSN-H30 … Remote Keyless Entry Transmitters … (3MR)
06/00/08 … 2008 … CSN-H11 … Radio Software Update … (3MR)
08/00/06 … 2006 … CSN-F35 … Engine Connecting Rod Bearing Debris (3.5L engines only) … (3MR)
06/00/06 … 2006 … CSN-F27 … Replace Manifold Absolute Pressure Sensor (LE export only) … (3)
05/00/06 … 2006 … CSN-F20 … Reprogram Wireless Control Module (LE export models only) … (3MR)
12/22/04 … 2005 … CSN-D36 … Instrument Cluster Gauge Accuracy - reprogram gauges … (3M)
11/01/04 … 2005 … CSN-D49 … Compact Spare May Contact Front Susp. Ball Joint Stud … (3M)
11/01/04 … 2005 … CSN-D50 … Radiator Isolator Brackets may crack … (3M)
11/01/04 … 2005 … CSN-D51 … Low Anti-Freeze Concentration Level … (3M)
07/02/04 … 2005 … CSN-D29 … Reprogram PCM - Electronic Throttle Control … (3M)
06/17/04 … 2005 … CSN-D27 … Tire and Loading Information Label … (3)
Part 2C: RAPID RESPONSE TRANSMITTALS
RRT Date .. Model Yr … RRT # …............................ Description...................... (Applicable models)
07/01/10 … 2010 … RR-10042 … Door Moldings … (C)
05/25/10 … 2010 … RR-10030 … RBZ Radio – Direct Tune Buttons Inoperative … (3C)
04/26/10 … 2010 … RR-10025 … Engine Rapping Sound (3.5L) … (3C)
04/22/10 … 2010 … RR-10023 … Cruise Control Inoperative … (3C)
03/26/10 … 2010 … RR-10019 … RBZ Radio - Video Disable … (3C)
02/26/10 … 2009 … RR-10013 … Sunroof Mechanism Cover Loose and or Cracked … (3C)
02/24/10 … 2010 … RR-10010 … Propeller Shaft Balance Weights Missing Or Inadequately Welded … (3C)
02/08/10 … 2009 … RR-10006 … Steering Wheel Returnability … (3C)
12/17/09 … 2010 … RR-09103 … REN Radio - Sirius Satellite Incorrect Programming For Canadian Models … (3C)
12/17/09 … 0910 … RR-09102 … Incorrectly Match Mounted Steel Wheels … (3C)
12/11/09 … 2010 … RR-09099 … Rear Defroster Switch Engagement Effort … (3C)
10/14/09 … 2009 … RR-09073 … Flash: Driveability Improvements (see TSB 18-030-09) … (SRT)
09/11/09 … 2010 … RR-09059 … 5/100 Powertrain Warranty (Owner Manual Kit Replacement) … (3C)
09/11/09 … 0608 … RR-09052 … Starter Harness (export models) … (3C)
08/25/09 … 2009 … RR-09051 … Loose Windshield Molding … (3C)
04/23/09 … 2008 … RR-09025 … Intermittent No Start / No Crank & Shifter Squeak Sound … (3C)
04/07/09 … 2009 … RR-09019 … No Start, Hard Start, Long Crank … (3C)
03/30/09 … 2009 … RR-09018 … MYGIG Radio - Splash Screen Frozen or Locked Up With Battery Drain … (3C)
01/23/09 … 2009 … RR-09005 … Right Camshaft Not Built To Proper Specification … (3C)
12/18/08 … 0809 … RR-08098 … Flash: Whistle Sound From Engine Compartment/Purge Solenoid … (3)
12/09/08 … 2009 … RR-08094 … Buzz Sound From Wireless Ignition Node (WIN) Module During Key Insertion … (3R)
10/29/08 … 2008 … RR-08076a . MYGIG Radio Update DVD For Many Radio Functional Issues And Improvements … (3MR)
10/14/08 … 2008 … RR-08080 … Engine Valve Train Ticking Sound … (3MR)
09/25/08 … 2009 … RR-08077 … Sirius Satellite Radio Inoperative … (3MR)
09/18/08 … 2008 … RR-08076 … MYGIG Radio Update DVD For Many Radio Functional Issues And Improvements … (3MR)
08/19/08 … 2007 … RR-08064 … Navigation Disks Have Missing Or Inaccessible Information For Major Euro Cities … (3)
05/27/08 … 2008 … RR-08047 … Flash: Vehicle in limp-in mode with no Diagnostic Trouble Codes set at start up (export models) … (3MR)
04/10/08 … 2008 … RR-08030 … Suspect Camshaft Position Sensor That May Set a MIL for P0340 and/or P0344 … (3MR)
03/06/08 … 2008 … RR-08019 … Incorrect Radio Station Frequency (export models) … (3MR)
02/13/08 … 2008 … RR-08012 … Install Front Tension Struts and Align Front End (Front Toe Set Only) (SRT8 export models) … (SRT)
02/13/08 … 2008 … RR-08011 … Front End Alignment (Front Toe set only) (export models) … (3MR)
01/18/08 … 2008 … RR-08004 … Right Front Door – Split Sheet Metal … (3MR)
01/11/08 … 2008 … RR-08002 … Right Front Door - Inside Paint Repair … (3MR)
12/07/07 … 2008 … RR-07052 … Flash Hands Free Module Emergency Phone Number 112 Not Supported … (3MR)
11/14/07 … 0708 … RR-07047 … Distorted Sound In 6x9 Speakers … (3MR)
10/03/07 … 2008 … RR-07038 … Rear Heated Seats Switch Works Opposite Side Seat … (3MR)
08/16/07 … 2007 … RR-07030 … Auto Dimming Exterior Passenger Mirror
08/02/07 … 0607 … RR-07026 … Engine Coolant Check on 3.5L and 6.1L engines … (3MR)
05/01/07 … 2007 … RR-07015 … Heated Seat Module - Replace, Charge & Test Battery, Replace if Necessary (export models) … (3MR)
03/07/07 … 2007 … RR-07007 … FLASH: Wireless Control Module (WCM) … (3MR)
05/02/07 … 2007 … RR-07003a .. FLASH: 3.5 L – California (Five State) Emissions, Mil Illumination … (3MR)
01/17/07 … 2007 … RR-07001 … Flash: Torque Converter Shudder Prevention/Shift Quality (2.7L only) … (3MR)
09/19/06 … 2007 … RR-06041 … FLASH – Front Control Module … (3MR)
09/01/06 … 2007 … RR-06034 … 2007 LX Oil Pressure Switch Harness … (3MR)
08/10/06 … 2006 … RR-06025b ..3.5L #2 Rod Bearing & Crankshaft Journal Inspection for Contamination … (3MR)
06/28/06 … 2006 … RR-06024 … Oil Cooler Line May Contact the Generator Pulley/Belt (Police package only) … (3MR)
04/05/06 … 2006 … RR-06017 … Piston Pin Retaining Ring … (SRT)
10/21/05 … 2006 … RR-05031 … Hood Release Cable Grommet Not Seated … (3MR)
09/27/05 … 2006 … RR-05027 … Sunroof Will Not Close (Flash) … (3MR)
09/13/05 … 2006 … RR-05025 … Engine Coolant Antifreeze Protection … (3MR)
08/26/05 … 2006 … RR-05023 … Relieve Tension In Left Downstream Oxygen Sensor Wiring … (SRT)
08/09/05 … 2006 … RR-05020 … FLASH - Wireless Control Module Ignition Off Draw … (3MR)
05/05/05 … 2006 … RR-05007 … Glove box - Incorrect Kit … (3M)
11/05/04 … 2005 … RR-04026 … Engine Cooling Module Revision … (M)
10/08/04 … 2005 … RR-04023 … Transfer Case Vent Hose Mis-routed … (M)
06/30/04 … 2005 … RR-04016 … Coolant Recovery/Overflow Container Inspection … (3M)
05/28/04 … 2005 … RR-04013 … No Start or Transmission In Limp-In Mode … (3M)
--Compiled and maintained by ResumeSpeed 2005-2009
Section 3: Chart notes
Model Year column:
Model Year "2005" = 2005 models
Model Year "2006" = 2006 models
Model Year "2007" = 2007 models
Model Year "2008" = 2008 models
Model Year "2009" = 2009 models
Model Year "2010" = 2010 models
Model Year "0506" = 2005 & 2006 models
Model Year "0507" = 2005 through 2007 models
Model Year "0607" = 2006 & 2007 models
Model Year "0508" = 2005 through 2008 models
Model Year "0509" = 2005 through 2009 models
Model Year "0510" = 2005 through 2010 models
Applicable models code:
(3) = 300 series (may apply to ALL 300 series models including SRT8)
(N) = 300N (may apply to ALL 300N series models)
(M) = Magnum (may apply to ALL Magnum models including SRT8)
(R) = Charger (may apply to ALL Charger models including SRT8)
(SRT) = SRT8 models ONLY (Magnum, Charger and/or 300C)
Examples: (3M) = 300 and Magnum; (3MR) = 300, Magnum and Charger
TSB numbering
The first two digits of all TSB numbers represent the category group. The middle three digits denote the category issue sequence, while the last two represent the calendar year in which the TSB was issued.
Example: 18-036-08
In the example above, bulletin # "18-036-08" is in the "Performance" category (group 18), and was the 36th Chrysler TSB released for this category (036) in calendar year 2008 (08). A letter at the end, as in "18-036-08a", designates a revision and or update, and always supersedes the prior bulletin.
TSB Groups
02 - Suspension
03 - Driveline/Axle
05 - Brakes
07 - Cooling
08 - Electrical
09 - Engine
11 - Exhaust
14 - Fuel
16 - Prop Shaft & U-Joint
18 - Performance
19 - Steering
21 - Transmission
22 - Wheels
23 - Body
24 - Heating &AC
25 - Emissions
26 - Miscellaneous
Important:
Some bulletins may apply only to specific production dates, models and/or equipment. Not all affected vehicles will exhibit described problems, failure rates may vary widely. Not all bulletins involve repair issues, some are issued for informational purposes only.
TSB's ARE NOT RECALLS. SERVICE BULLETINS ARE NOT A WARRANTY ITEM FOR VEHICLES OUT OF WARRANTY. It is important to note that "Preventive" service repairs will generally not be performed under warranty during the normal warranty period if a vehicle is not exhibiting the particular symptom or problem. If you ask your dealer to perform the modification outside of the warranty period, expect to pay for the labor and parts.
For vehicles that are out of warranty, any TSB related work that is performed is usually charged at the normal dealer service rate.
Section 4: Buzz, Squeaks and Rattles
2005 LX
1. Rattle / tapping noise in the left front fender area when driving at highway speeds.
Verify that the driver side bumper light wiring harness is positioned properly.
Recommendation: The driver side bumper light wiring harness may be out of place causing it to move back and forth while hitting against the foam bumper pad. Reinstall / replace the plastic tree back into the hole and tape the wiring harness against the foam bumper pad as necessary.
2. Fender , Quarter Panel , Wheel Well Rattle, Rear; Parking Lot Maneuvers, After Hitting A Bump
This condition may occur any time the vehicle flexes. This noise could also be described as coming from the tail lamp area or the rear of the vehicle.
Recommendation: Lube the rear seat latch striker.
3. Rattle, Parking Lot Maneuvers , After Hitting A Bump
Two sources discovered so far: (1) deck lid hinge stopper rattling against height adjuster screws on the hinges, and (2) found bundle of rear wiring harness and battery cable rattling against body due to broken holder.
Originally, source of rattle from trunk was found to be the decklid hinge stopper/bumper on upper half of hinge hitting the height adjuster screw head on the lower half of the hinge. The adjusters were too low and had to be raised.
Recommendation: The first cause was addressed by adjusting height adjuster screws up by turning 1.75 turns, The second source of rattle was addressed by securing the bundle of wiring harness and battery cable with a tie strap.
4. Rattle from under the vehicle
Noise may occur anytime on any type of road, while driving and when braking. Inspect for contact between the exhaust cross over pipe and the transfer case skid plate.
Recommendation: If contact is noted, loosen the exhaust manifold nuts and move the exhaust assembly upward so that it will not make contact with the transfer case skid plate. Torque the exhaust manifold nuts to spec.
5. Rattle, Left Front
Check the VIN plate rivet and verify that the crimp is proper, if the the end is not cut flush and is contacting the windshield creating a rattle, perform the following repair.
Recommendation: Crimp the end of the rivet on the VIN Plate and cut flush.
6. Noise from rear of vehicle when driving over bumps in the road
Recommendation: A plastic cover blocking the hole cutout for the rear deck mounted woofer may be loose and rattling. Verify the blocker is correctly installed.
7. Rattle Coming From The Lower Rear Of Vehicle
Rattle is coming from rear of vehicle. Rattle may be misdiagnosed as coming from the suspension or body.
Recommendation: Remove exhaust hanger and shake exhaust system listening for a rattle from the muffler. If the muffler is the source of the rattle noise, replace the muffler.
8. Rear speaker buzzing, distortion, rattling (300 series models only)
Rear speaker buzzing, distortion, rattling, or other objectionable noises.
Recommendation: See TSB 23-007-05. The TSB involves adding foam strips to rear parcel shelf sheet metal to insulate from trim panel, and removing the shelf panel plug used when a subwoofer speaker is not present.
9. Rattle From The Rear Suspension And A Groan When Turning
Inspect for the muffler contacting the left heat shield. Also check for the rear tail pipe (between the muffler and resonator) grounding out against the rear suspension crossmember. Loosen all of the clamps and bolts. Reposition the exhaust system to provide necessary clearance. Test drive to confirm noises are eliminated.
Recommendation: Towards the rear of the exhaust system the left side of the muffler may be pushed against the left heat shield. This will cause the exhaust drone (groan). Continuing to the rear the left tailpipe (between the muffler and resonator) may be grounding against the rear suspension crossmember. This will cause the rattle from the rear suspension.
10. Brake pedal pulsation, ratcheting noise
The Traction Control on the LX, when activated, will use engine management and ABS to control wheel slip. If the traction control is defeated, then the system will act as if the car has a limited slip differential. When in this mode, engine management will be defeated and the brake traction control will modulate the rear brake calipers to maintain traction. Therefore, traction control is never completely turned off and the brake modulation / sound is normal.
2005-2006 LX
1. Metallic rattle sound in the area of the sunroof
Rattle occurs when driving on rough roads, is a metallic sound, can be moderate to severe and typically occurs after 6000 miles are on the vehicle. The rattle can be duplicated by tapping/pounding up on the sunroof glass panel.
Recommendation: See TSB#: 23-002-06
2006 LX
1. Sill Cladding Rattle Sound
A rattle sound can be heard at speeds of 40 - 50 mph (65 - 80 kph) at higher temperatures 80 - 90°F (26 - 33°C), especially during cross wind conditions. The sound may be mistaken for a lower door rattle. The rattle sound is caused by contact between sill cladding flange and lower body side pinch weld.
Recommendation: See TSB#: 23-005-06
2. Headliner rattle rearward of the sunroof opening (Charger only)
Rattle occurs when driving on a fairly rough road and can be duplicated by lightly tapping on the headliner rearward of the sunroof opening. The root cause of the rattle is a loose (unsecured) cardboard stiffener on the headliner substrate.
Recommendation: Drop the headliner from the sunroof trim lace at the rear of the opening. Inspect to see if the headliner stiffener is secured to the headliner substrate. If the stiffener is loose remove it. The stiffener can be removed by prying up using a fiber/trim stick. Start at one end and work across car to fully disengage the stiffener and remove it. The stiffener is only used on the Charger and is only required for plant processing.
2007 LX
1. Instrument Panel Buzz or A/C Compressor Noise (2007 3.5L LX built between 07/24/06 to 02/05/07)
Recommendation: Before tearing the I/P apart or replacing the A/C Compressor have the Tech check the A/C compressor mounting bolts to make sure they are torqued to 25-31 Nm (18-22 lb.ft)
2. Rattle from the “A” pillar area of the instrument panel.
The rattle sounds metallic and or creak/squeak. The rattle usually occurs under normal driving conditions. If the rattle is repeatable, try pushing down on either side of the IP at the “A” pillars. If the rattle does not go away, it may be the hood flushness adjusting plastic bolt rattling within the hood hinge.
Recommendation: Open the hood and in the hood hinge assembly you will see a hood flushness adjusting bolt. This is the suspect part. Turn the bolt head ¼ - ½ turn counter clockwise. This will insure full contact of the bolt head to the hinge. Close the hood and try to repeat the rattle.
3. Moderate to severe I/P rattle left side (all 2007 LX models built December 2006-March 2007)
This BSR (Buzz, Squeak, Rattle) is severe in nature and will occur on most road surfaces. The rattle may be temperature sensitive and be worse in cold ambient conditions. The rattle will appear to be coming from the I/P defroster cover to windshield interface directly in front of the driver. While driving the vehicle, with the BSR present, press down on the I/P defroster cover. If pressing down on the cover does not affect the noise, the BSR may be result of the windshield contacting the plenum sheet metal.
Recommendation: If the windshield is contacting the plenum sheet metal the glass must be removed and repositioned to eliminate the BSR. Prior to removing the glass make sure the rattle is not due to the hood flushness bumper BSR (the hood flushness bumper BSR can be eliminated by turning the flushness bumpers ½ turn counter clockwise). The windshield to plenum BSR has been seen on LX vehicles built between 12/06 and 03/07. After the glass is removed inspect the PIA clips holding down the plenum silencer. Make sure all the plenum silencer PIA clips are fully seated into the BIW prior to installing the windshield.
4. Rattling or Clattering Noise heard from the Serpentine Belt area with the A/C on.
This noise is most noticable under a load with A/C on at operating temp.
Recommendation: This noise could be cause by the Serpentine Belt Tensioner. The noise is usually noticed during PDI of the vehicle or at VERY LOW MILEAGE. If it has been determined that the belt tensioner is the source of the noise replace with old Litens Tensioner (p/n 04861660AA) using the Service Procedure in TechCONNECT.
2008 LX
1. Grounding or popping sound from the floor on turns
Review all exhaust components and align to proper clearance. Exhaust repositioning was performed to resolve. Catalytic converter clearance to floor was increased by repositioning the exhaust to resolve.
