1 - 2 of 2 Posts
What tire has the most meat for 22 inch rims?
Similar to
NITTO NT01 COMP RADIAL TIRES - N371-090
I love the look of the tire, notbso many cuts. Looks very aggressive. I've been trying to look for something similar, but haven't found anything to my satisfaction. New to tire brands in general. I've always just bought used tires, but now I actually have a car I want to baby.
On a side note, I have some 6.1 heads with the intake valves a little bent, eady fix right? They feel victim to my mechanic misunderstanding of what parts were needed for a cam I wanted put in during a rebuild and ended up using new heads.
My question is, will they fit on a 5.7l (which I also own). Or is it better off to fix and sell? I think I have some lifter issues going on with the 5.7l so this is why I'm considering it.
Thanks in advance for all advice and help!
Super Moderator
If you buy different wheels you need to check to make sure the offset is correct. I can't offer help with 22's as I personally would go bigger than 20's. The less side wall the worse the ride, and that is a nice feature of the 300's
Reactions: Kuckle
1 - 2 of 2 Posts
