Hi, does anyone have any experience of what I think is a fusible link cable spliced into the starter motor cable breaking or what looks like been rubbed away then melted.
It's located below the bell housing and attached to a mounting bracket along with 3 or 4 other connectors which appear to go to sensors on the exhaust system.
This was only spotted when I removed the covers underneath trying to locate a problem with the alternator not charging and a long cranking time before the engine would fire up I decided to investigate.
I suspect this has something to do with the alternator fault and that the glow plugs are not working either.
I would attempt to repair the cable but feel it is beyond the scope of a domestic soldering iron and that the original splice was covered with specialist sleeving.
Question is can this section of harness be purchased as a replacement part and more importantly why it happened in the first place.
Any advice would be appreciated.
