hey guys i got a problem i just installed the motorad 4128 t stat and it didnt seem to make a difference my engine temps are still quite high and suggestions?
fans
you must re-program your fans via Diablo or other to run at different temps or the thermostat cannot help you.
Your temps should be lower on the highway though.
Or do a fan mod to turn them on at lower temps.
Jacksonbeall2889:
About a year-and-a-half ago I did a automatic, thermostatically-controlled fan mod that I developed from the simplistic manual switch fan override developed and presented by others on this and other forums.
I posted it on the forum here:
http://www.300cforums.com/forums/pe...n-mod.html?highlight=automatic+fan+controller
The real trick is the diode added into the relay as it prevents the check engine light from coming on as occurs without it.
You don't have to do the whole automatic thing with the auxiliary relay, the thermostatic switch, etc., etc., just the diode added to the relay and a ground switch on the "ADD WIRE" lead extended to whereever you place the switch. You can flick the switch anytime you want the fans turned on or off. I automated mine to eliminate my having to do the switching manually.
The relay, diode, switch, and some hook-up wire will cost you less than $20. The fully automatic setup costs $65.
Recently I got a Predator ($350 +/-) for its performance-enhancement features and other capabilities, which eliminated the need for my automatic fan controller. I left it installed as a backup in the event I should need to re-install the stock tune.
Other
Desiree,
The reason I said "or other" was to include all the home made solutions such as yours.
