1 - 19 of 19 Posts
Hey 300 family:
Is anyone having trouble creating or playing a MP3 disc in their car. I have been up all night trying to create a MP3 disc and I finally was able to rip a disc to my computer using windows media player 10. I then used a drag and drop method to send them from the computer to a blank formatted disc. After putting only three albums on there
i ran out to the car to see if it would work and when I inserted the disc it said"improper disc" PLEASE HELP.
Thanks
I wouldn't mess with Windows Media player. Use an MP3 ripper/player instead. There are many out there but I mostly use the free Music Match software. You can download it here.
http://musicmatch.com/download/free/?OS=pc&MODE=input&DID=&OEM=MMD&LANG=&SOURCE=getbasic_jbpromo
It's quite easy to setup and convert CD's to MP3's. I've never had any problems with it and the disks have played in all MP3 players that I've ever tried them on including my crappy 3 year old DVD player.
I used NERO 5 (or 6). Make sure the CD format is ISO and you shouldn't have any problems.
HEMIFIED said:
Hey 300 family:
Thanks
Which radio do you have? The basic radio will not play mp3s. The 6 disc radio will play them, but do not go over 100-150 mp3s per disc. For some reason the radio acts up when you put too many mp3s.
Rmedina
Yup, if you burn over a 100 mp3's the disc will get stuck and will not work. I don't know why it does this but it kind of sucks that you can burn max mp3's on one disc.
· Premium Member
Really? I've played over 100 and it was ok. Can't say I've gone past 150 though, since space doesn't allow if they are a high enough bitrate or are VBR. Nero works well as mentioned above. I do like the ability to select directories... works out well.
I have a question for you audiophiles. I have a Nero CD burner and want to download all my CD's to MP3 format. Is there a free download site where I can store my CD's prior to burning? This may be a stupid question but when I download my CD, does it do it at super speed or do I have to wait for it to go through the whole disc at normal speed? I have over 200 discs in my car and I will be really old (older) if I have to wait.
I do have Limewire on my computer. Will this be good enough? Thxs. :confused:
250 MP3s
I love to listen to MP3s in my car. I also listen to alot of books on cd in MP3 format driving back and forth to work. I believe the limit is 250 MP3s and that is what I have found with my audiobooks. No issues and have listened to 15+ audio books and 20+ burned MP3s cds that are over 100 songs. Too many freaking CD sitting in my car.
I should just buy a 30GB IPOD and have the stereo MOD done. :hmmm:
Jon300C
Kansas City, MO
Jon300C
Kansas City, MO
...see this thread (post #5) SGII limitations thread
I have downloaded two different music sharing sites, Limewire and Gnutella, and I did this so that I could have a library to download all my CD's then burn them onto MP3 discs.
I talked to a fellow last night and he tells me that I can't do this because of incripted codes in CD's. I seem to recall that others have done this. I have about 200 discs in my trunk and sure would like to condense them onto MP3.
I have the latest Nero burner on my system and two disc players (?) on my computer.
Can someone please tell me if I can do what I want and if so what is the easiest way to do it? Thx. Mike.
MGD said:
Use windows media player 10, insert the CD and click on rip. it's rips the cd to mp3 and you can save the where you want. It works very well.
I was able to rip about 5 of my discs onto windows media and then was able to put them into a place where they could be burned but there was no area where it could be converted to MP3. It would only burn about 1 and a half dics. There must be a remedy to this. Any ideas? Sorry for being such a pain.
· Administrator
Mikey, below is my post from another thread... there are other suggestions in that thread as well at http://www.300cforums.com/forums/showthread.php?t=5973&highlight=easy+extractor, but this is a great program that pretty much does it all... Good Luck!
I've found Easy CD-DA Extractor to be, as they say, easy... and very versatile all the way around. You can download a 30-day free trial version here. It's stripped of a few features and is not full speed, but if you like it, it's only $25 to buy the faster full-featured version.
Features:
Rips Audio CD's
  • High performance CD-ripping
  • Copies "Copy-Protected" CD's
  • Reads badly scratched CD's
  • Download disc data from thefreedb (database)
  • Advanced sound processing
  • Creates Cue Sheets (.cue)
  • Creates Playlists (.m3u)
  • Supports CD-Text
  • Supports ID3, ID3V2, and other format specific metadata
Converts audio files from one format to another
  • Convert audio files from a format to another
  • Splits Cue Sheets (.cue) and encodes them to individual files
Creates Audio CD's
  • Writes Audio CD's that are compatible with all CD-players
  • Writes CD-Text
  • Supports Cue Sheet (.cue) files
  • Supports buffer underrun prevention technologies
Easy CD-DA Extractor supports the following audio file formats: MP1, MP2, MP3, Windows Media Audio 8, Windows Media Audio 9, Windows Media Audio 9.1, Ogg Vorbis, MP4, M4A, AAC, FLAC, Musepack, VQF, WAV, AIFF, Monkey's Audio, Shorten, CUE and M3U. Also, the Nero Digital (Nero AAC) is supported if you have the Nero Burning ROM installed on your computer.
More info & download here: http://www.poikosoft.com/index.html
Features:
Rips Audio CD's
  • Supports CD-Text
Creates Audio CD's
  • Writes CD-Text
Thanks Linda, I'll give it a look, I'm getting mighty frustrated!!!!!!
I finally got this thing figured out and have converted all my CD's to about 6 discs. The problem I was having is that they had to be burned as a data disc not an MP3 disc. I now use music match (paid version) to store my songs and then Nero6 to burn. I find the sound quality to be excellent but then I have damaged hearing from my military and police career. :banana: :banana: :banana:
1 - 19 of 19 Posts
