1 - 10 of 10 Posts
Had my beasty for 2 years, done 45k miles and been averaging all that time approx 32mpg (never reset the mpg on the computer all that time). Last two weeks I noticed it dropping to below 30mpg. Reset the MPG and I am struggling to get it above 28mpg combined. Just had a service and they found no issues so need some ideas form the "brain trust" please as to what to look for.
Something must of happened as its a sudden decrease not a gradual.
Cheers
Steven
I wouldn't call that "dropped off a cliff". You're comparing a long-term average with a short-term average and there's no guarantee that they will be close. A short-term value will be influenced by driving style, traffic conditions, length of journey and at this time of year, weather. Over the past couple of weeks my mpg has dropped by a similar amount, which I have attributed to colder weather, longer nights and shorter trips. The 1kW electric cabin heater and rear screen heater will provide a heavy load on your alternator, not to mention any use of the seat heating. Have you checked your tyre pressures and not just by the EVIC, but with a manual gauge? Pressures will be reduced in cold weather and this can have a negative effect on mpg. I don't think you should be too concerned about a variation of 32-28 over a short term.
2014 CRD
Mine drops one or two mpg when it's really cold too. Also have you checked tyre pressures?
Bit dramatic I agree. for the first 45000 miles it was averaging 32-34 on the computer, then in the space of 1 tankful that 45000 mile average dropped below 30mpg, that tankful was driving to Paris so mostly constant 85mph cruising. I will leave the computer running now its been serviced to see if it creeps up, just seemed to me that it feels like something changed or happened to create the decrease as so out of character to the previous 2 years.
There's your answer. I suspect you normally cruise here at a slightly lower speed?
ahhh no, normally a tad higher over here if not the same :p
Right so I am still struggling to get above 28.8mpg on a tank of combined driving. Something is definitely different than before.
Last night I undertook a test, cruised at 80mph for 3 miles on cruise control and averaged 30.4mpg. That is not right, over the 450000 miles previously, 70% was motorway and most of that was 80-90mph driving. I should be able to get over 30.4mpg at 80mph.
Tyre pressures are min 2.4
Brakes not binding as had them checked
Serviced 500miles ago
so my thoughts are;
1 Fuel Leak
2 Running rich (if it can with a diesel)
3 Whatever it does when the engine is cold is not shutting down when the engine is warm
4 ECU is on its way out
5 Startech Sd6 box is on its way out
Thoughts?
Steven
1 - 10 of 10 Posts
